paulonichio
- Jul 8, 2019
The same problem occurs here.
Search does not work after update.
Domain bexx.yy Created: Domain Created Successfully
Error restoring domain: Unable to read %s : %s/home/bexx/backups/backup/bexx.yy/domain.pointersUnable to open /home/bexx/backups/backup/bexx.yy/domain.pointers for reading.
No such file or directory
alpha
release channel. You should not be getting these errors if you have DA from beta
or current
. Issues with double login are also only present in alpha
we are experimenting with different login page there 8b289ccb2ff29cc20ac0ddb15f639284070fd9e3
.I was unable to reproduce it. Are you sure it’s latest version of custombuild?MariaDB 10.3.34 update to 10.3.35 error, using [files.directadmin.com] downloadserver
Downloading mysql/centos7-64.txt...
######################################################################## 100.0%#=#=#
Downloaded file /usr/local/directadmin/custombuild/mysql/centos7-64.txt does not exist or is empty after download
cwd is: /usr/local/directadmin/custombuild
Fileserver might be down, using the backup file server..
grep: mysql/centos7-64.txt: No such file or directory
Done!
Hi!@apogee you are probably usingalpha
release channel. You should not be getting these errors if you have DA frombeta
orcurrent
. Issues with double login are also only present inalpha
we are experimenting with different login page there.
@dmtinc, @paulonichio thanks a lot! We have pushed an update with a fix for a search bar issue, new build ID is8b289ccb2ff29cc20ac0ddb15f639284070fd9e3
With a custom docroot, where, for example, would you want to place maindomain.com in the user's directory hierarchy?runs on my alpha boxes, I see there is now "maintenance" which checks the paths, this brings me back to the old topic with custom docroot on maindomains, definable by the end user, what about this? we need this UNCONDITIONALLY! If it is absolutely necessary, make it available only for propack users but the feature must now come!
@dafang Yes this one is confirmed will be fixed soon. Root cause for this actually the change in the order in which we load Evo routes (the URL patterns that changes when navigating between pages). But we are making sure we eliminate all ambiguous routes (that depend on load order) not only the reported ones.
the problem is contao, codeigniter and lavarel and many other systems which have their public stuff in an separate folder like "public" or "web" and so on. Sure I can set the docroot in DA but this must be done by our staff, the clients don't have the patience to wait for support and therefore go to other companies that offer it.... eg: domain maindomain.com, location (docroot) should now be "/home/mainuser/domains/maindomain.com/public_html/public".....With a custom docroot, where, for example, would you want to place maindomain.com in the user's directory hierarchy?
Try:I get the same.
Hm, strange. I was unable to reproduce it. May you try this:Version 2.0.0 (rev: 2902)
and i try today , get different error :
######################################################################## 100.0%##O#-#
Found /usr/local/directadmin/custombuild/mysql/MariaDB-client-10.3.35-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-devel-10.3.35-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-server-10.3.35-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-shared-10.3.35-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-common-10.3.35-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-compat-10.3.35-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-backup-10.3.35-1.el7.centos.x86_64.rpm
Installing dependencies...
Installing libjemalloc...
Found /usr/local/directadmin/custombuild/mysql/jemalloc-3.6.0-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/jemalloc-devel-3.6.0-1.el7.x86_64.rpm
warning: /usr/local/directadmin/custombuild/mysql/jemalloc-3.6.0-1.el7.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 1bb943db: NOKEY
Preparing... ########################################
Updating / installing...
jemalloc-3.6.0-1.el7 ########################################
jemalloc-devel-3.6.0-1.el7 ########################################
Installing galera...
Found /usr/local/directadmin/custombuild/mysql/galera-4-26.4.8-1.el7.centos.x86_64.rpm
warning: /usr/local/directadmin/custombuild/mysql/galera-4-26.4.8-1.el7.centos.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 1bb943db: NOKEY
galera-4-26.4.8-1.el7.centos ########################################
Stopping mysqld ...
Service didn't get stopped, sleeping for 20 secs and re-trying ...
Stopping mysqld ...
Updating MariaDB 10.3.34 to 10.3.35
warning: MariaDB-client-10.3.35-1.el7.centos.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 1bb943db: NOKEY
MariaDB-compat-10.3.35-1.el7.centos ########################################
MariaDB-common-10.3.35-1.el7.centos ########################################
MariaDB-client-10.3.35-1.el7.centos ########################################
error: unpacking of archive failed on file /usr/bin/mysql;62edcf8a: cpio: read failed - Inappropriate ioctl for device
error: MariaDB-client-10.3.35-1.el7.centos.x86_64: install failed
MariaDB-shared-10.3.35-1.el7.centos ########################################
MariaDB-devel-10.3.35-1.el7.centos ########################################
error: unpacking of archive failed on file /usr/lib64/libmariadbd.a;62edcf8a: cpio: read failed - Inappropriate ioctl for device
error: MariaDB-devel-10.3.35-1.el7.centos.x86_64: install failed
MariaDB-server-10.3.35-1.el7.centos ########################################
error: unpacking of archive failed on file /usr/bin/aria_chk;62edcf8a: cpio: read failed - Inappropriate ioctl for device
error: MariaDB-server-10.3.35-1.el7.centos.x86_64: install failed
MariaDB-backup-10.3.35-1.el7.centos ########################################
error: unpacking of archive failed on file /usr/bin/mariabackup;62edcf8a: cpio: read failed - Inappropriate ioctl for device
error: MariaDB-backup-10.3.35-1.el7.centos.x86_64: install failed
error: MariaDB-server-10.3.34-1.el7.centos.x86_64: erase skipped
error: MariaDB-client-10.3.34-1.el7.centos.x86_64: erase skipped
error: MariaDB-backup-10.3.34-1.el7.centos.x86_64: erase skipped
error: MariaDB-devel-10.3.34-1.el7.centos.x86_64: erase skipped
Created symlink from /etc/systemd/system/mysql.service to /etc/systemd/system/mariadb.service.
Created symlink from /etc/systemd/system/mysqld.service to /etc/systemd/system/mariadb.service.
Ensuring local-infile is disabled for security reasons in MySQL configuration file...
Giving mysqld a few seconds to start up...
This installation of MariaDB is already upgraded to 10.3.32-MariaDB.
There is no need to run mysql_upgrade again for 10.3.34-MariaDB.
You can use --force if you still want to run mysql_upgrade
Restarting MySQL.
Installation completed.
Done!
wget -O /usr/local/directadmin/custombuild/build http://files1.directadmin.com/services/custombuild/2.0/custombuild/build
rm -rf /usr/local/directadmin/custombuild/mysql
/usr/local/directadmin/custombuild/build update
/usr/local/directadmin/custombuild/build mysql
Code:wget -O /usr/local/directadmin/custombuild/build http://files1.directadmin.com/services/custombuild/2.0/custombuild/build rm -rf /usr/local/directadmin/custombuild/mysql /usr/local/directadmin/custombuild/build update /usr/local/directadmin/custombuild/build mysql
