1.) Sorry, can't help you with that. I never used cloudflare for DNS before, so I don't know how to set that up or if there is a problem.
2.) Where, in cloudflare? Anyway I don't use cloudflare, so I don't know.
3.) IntoDNS says that's good, but if I do a nslookup on ns1.hostcardano.com it does not give me the correct ip, could be caused because DA is not responding on port 53 requests.
4.) Might be good, can't say from here. If it's like in your first screenshot then it's good.
Did you open the necessary ports in your firewall?
Maybe it's due to some error in the /etc/named.conf that might also be possible. Because it seems ns1 is still not responding.
Can you give the output of this command:
lsof -i:53
I waited 3 days to see if the dns could propagate, but nothing, it still does not work
I have removed the cloudflare and now I am pointing the nameservers directly to my server ip
the firewall is open
lsof -i:53
still not working, I waitted a few days to see if it was the dns replication but nothing
now I am not using cloudflare anymore, I pointed the ns directly to the server ip
port 53 seems to be open when I try a port scanner and the result of the command you ask is this
[root@server1 ~]# lsof -i:53
COMMAND     PID            USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
systemd-r 58163 systemd-resolve   17u  IPv4 283193      0t0  UDP 127.0.0.53:domain
named     79662           named   21u  IPv6 380275      0t0  TCP *:domain (LISTEN)
named     79662           named   22u  IPv4 380279      0t0  TCP localhost:domain (LISTEN)
named     79662           named   23u  IPv4 378515      0t0  TCP server1.hostcardano.com:domain (LISTEN)
named     79662           named   24u  IPv4 378517      0t0  TCP server1.hostcardano.com:domain (LISTEN)
named     79662           named  512u  IPv6 380273      0t0  UDP *:domain
named     79662           named  513u  IPv6 380273      0t0  UDP *:domain
named     79662           named  514u  IPv6 380273      0t0  UDP *:domain
named     79662           named  515u  IPv4 380278      0t0  UDP localhost:domain
named     79662           named  516u  IPv4 380278      0t0  UDP localhost:domain
named     79662           named  517u  IPv4 380278      0t0  UDP localhost:domain
named     79662           named  518u  IPv4 380280      0t0  UDP server1.hostcardano.com:domain
named     79662           named  519u  IPv4 380280      0t0  UDP server1.hostcardano.com:domain
named     79662           named  520u  IPv4 380280      0t0  UDP server1.hostcardano.com:domain
named     79662           named  521u  IPv4 378516      0t0  UDP server1.hostcardano.com:domain
named     79662           named  522u  IPv4 378516      0t0  UDP server1.hostcardano.com:domain
named     79662           named  523u  IPv4 378516      0t0  UDP server1.hostcardano.com:domain
[root@server1 ~]#
