clamd@scan - can't run
djcart
I'm having trouble starting the clamd@scan service. When I try to do it from SSH, it takes a very long time to start up. When it finally starts, it shuts down after a while.
[root@server server]# service clamd@scan start
Redirecting to /bin/systemctl start [email protected]
[root@server server]# service clamd@scan status
Redirecting to /bin/systemctl status [email protected]
[email protected] - clamd scanner (scan) daemon
Loaded: loaded (/usr/lib/systemd/system/[email protected]; enabled; vendor preset: disabled)
Active: activating (start) since Wed 2023-03-01 14:22:11 CET; 6s ago
Docs: man:clamd(8)
man:clamd.conf(5)
https://www.clamav.net/documents/
Main PID: 3949040 (code=exited, status=0/SUCCESS); Control PID: 3952652 (clamd)
Tasks: 2 (limit: 1234569)
Memory: 718.9M
CGroup: /system.slice/system-clamd.slice/[email protected]
├─3952652 /usr/sbin/clamd -c /etc/clamd.d/scan.conf
└─3952654 /usr/sbin/clamd -c /etc/clamd.d/scan.conf
mar 01 14:22:11 server.server.pl systemd[1]: Starting clamd scanner (scan) daemon...
Active: activating (start) since Wed 2023-03-01 14:22:11 CET; 2min 20s ago
Docs: man:clamd(8)
man:clamd.conf(5)
Memory: 1.2G
mar 01 14:24:31 server.server.pl clamd[3952654]: LibClamAV Warning: Detected duplicate databases /var/lib/clamav/bytecode.cvd and /var/lib/clamav/bytecode.cld, please manually remove one of them
Active: deactivating (stop-sigterm) since Wed 2023-03-01 14:46:23 CET; 63ms ago
Docs: man:clamd(8)
man:clamd.conf(5)
Process: 3992737 ExecStart=/usr/sbin/clamd -c /etc/clamd.d/scan.conf (code=exited, status=0/SUCCESS)
Main PID: 3992739 (clamd)
Tasks: 1 (limit: 1234569)
Memory: 1.2G
└─3992739 /usr/sbin/clamd -c /etc/clamd.d/scan.conf
mar 01 14:43:59 server.server.pl systemd[1]: Starting clamd scanner (scan) daemon...
mar 01 14:46:18 server.server.pl systemd[1]: Started clamd scanner (scan) daemon.
mar 01 14:46:23 server.server.pl systemd[1]: Stopping clamd scanner (scan) daemon...
It loops and can't start
Same problem here but only with almalinux 8 and rhel 8.
I think can be related with this update:
2023-03-01T06:04:28-0300 DEBUG Upgraded: clamav-0.103.8-3.el8.x86_64
2023-03-01T06:04:28-0300 DEBUG Upgraded: clamav-data-0.103.8-3.el8.noarch
2023-03-01T06:04:28-0300 DEBUG Upgraded: clamav-devel-0.103.8-3.el8.x86_64
2023-03-01T06:04:28-0300 DEBUG Upgraded: clamav-filesystem-0.103.8-3.el8.noarch
2023-03-01T06:04:28-0300 DEBUG Upgraded: clamav-lib-0.103.8-3.el8.x86_64
2023-03-01T06:04:28-0300 DEBUG Upgraded: clamav-update-0.103.8-3.el8.x86_64
Even after remove clamav and reinstalling, the problem persists.
Exactly the same packages have been updated for me. I am using Cloudlinux.
Also trying to reinstall didn't help. The process is killed when it starts
Is it possible to install the version from before the update?
@djcart error looks to be the duplicate database from an update
mar 01 14:24:31 server.hostline.pl clamd[3952654]: LibClamAV Warning: Detected duplicate databases /var/lib/clamav/bytecode.cvd and /var/lib/clamav/bytecode.cld, please manually remove one of them
Make a backup but try removing the /var/lib/clamav/bytecode.cld file and restart service.
@dmtinc are you also on Cloudlinux or just normale Almalinux 8?
and
I've found the same error from some years ago. Seems clamav-data is obsolete and does not need to be installed anymore and they forgot to get it out.
Could you try this and look if this fixes the issue?
dnf remove clamav-data
Edit: you might also need to remove both the bytecode.* files and then restart freshclam to get a new database update.
Here's what I found in the clamd.scan logs
and
Just Almalinux and RHEL, not cloudlinux, but the package (clamav) depends on epel, I dont know if the cloudlinux kernel can do a difference.
Even after remove the "clamav-data" package, the problem still.
I'm trying or looking for a workaround, as the epel packages cant be downgraded with yum/dnf (because epel removes the old packaged with a new one its published).
I can write a ticket but the question is whether to write to cloudlinux or DirectAdmin?
Neither I guess. Since the issue is occuring on both DA and Cloudlinux and after the clamav update, which is an OS update, it's most likely an OS clamav issue.
I also have the "normal" (so no Cloudlinux) Alma. I'm going to update now and see what happens.
Update went fine, no issues, no stopping.
Status also showed all fine.
Restarting the clamd@scan service takes a lot of time (often), but this time indeed extra long.
But still fine, no error notices.
[root@server: ~]# service clamd@scan status
Redirecting to /bin/systemctl status [email protected][email protected] - clamd scanner (scan) daemon
   Active: activating (start) since Wed 2023-03-01 15:53:42 CET; 24s ago
     Docs: man:clamd(8)
           man:clamd.conf(5)
 Main PID: 2175595 (code=exited, status=0/SUCCESS); Control PID: 2175760 (clamd)
    Tasks: 2 (limit: 203028)
   Memory: 927.2M
           ├─2175760 /usr/sbin/clamd -c /etc/clamd.d/scan.conf
           └─2175762 /usr/sbin/clamd -c /etc/clamd.d/scan.conf
Mar 01 15:53:42 server.wereldstadrtd.nl systemd[1]: Starting clamd scanner (scan) daemon...
Mar 01 15:53:42 server.wereldstadrtd.nl clamd[2175762]: Received 0 file descriptor(s) from systemd.
Mar 01 15:53:42 server.wereldstadrtd.nl clamd[2175762]: clamd daemon 0.103.8 (OS: linux-gnu, ARCH: x86_64, CPU: x86_64)
Mar 01 15:53:42 server.wereldstadrtd.nl clamd[2175762]: Log file size limited to 1048576 bytes.
Mar 01 15:53:42 server.wereldstadrtd.nl clamd[2175762]: Reading databases from /var/lib/clamav
Mar 01 15:53:42 server.wereldstadrtd.nl clamd[2175762]: Not loading PUA signatures.
Mar 01 15:53:42 server.wereldstadrtd.nl clamd[2175762]: Bytecode: Security mode set to "TrustSigned".
So I think you can add clamav-data again, since I have that running too. I do have bytecode.cld but not bytecode.cvd.
Try adding clamav-data again and remove the /var/lib/clamav/bytecode.cvd file and restart services.
How to add clamav-data?
@dmtinc Do you additionally use the Immunify software?
Noup, I dont use any related con cloudlinux or their subproducts.
But I have a workaround to downgrade the clamav version. ONLY for RHEL 8 or rhel8 based distros (almalinux8/rockylinux8/cloudlinux8/etc..)
(I host some linux public mirrors, so I use the same server to create a custom repo).
First, remove clamav:
** Dont execute this commands on the /usr/local/directadmin/custombuild directory, in /root/ will be fine
dnf erase clamav*
Exclude clamav from epel:
In /etc/yum.repos.d/epel.repo, add this line to the first repo:
exclude= clamav*
Must look like this
[epel]
name=Extra Packages for Enterprise Linux 8 - $basearch
# It is much more secure to use the metalink, but if you wish to use a local mirror
# place its address here.
#baseurl=https://download.example/pub/epel/8/Everything/$basearch
metalink=https://mirrors.fedoraproject.org/metalink?repo=epel-8&arch=$basearch&infra=$infra&content=$contentdir
enabled=1
gpgcheck=1
countme=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-8
exclude= clamav*
Add a new repo:
Create the file "nonprod.repo" in /etc/yum.repos.d/ with this content:
[nonprodclam]
name=Workaround to downgrade clamav rhel8
baseurl=http://mirror.hnd.cl/nonprod-clamd
enabled=1
priority=10
countme=1
Clean the local dnf/yum cache:
dnf clean all
Reinstall clamav using custombuild:
./build clamav
And done, clamav working fine again :)
You can check the repo content at:
Its just a work around to fix this until a new clamav version its released on epel.
I'm think DirectAdmin needs to provide repos for rhel/deb/ubuntu for the system required packaged (as cpa...) as work with external repos, always will be a bet of compatibility.
I don't think it's needed as I did not have any issues on my Almalinux 8.
Also I just updated both my centos 7 servers and they have both the bytecode files and no errors or issues there either.
Maybe the removal was not complete enough the first time you removed it? Wasn't it enough to remove the bytecode.cvd file maybe?
Building clamav via custombuild will use the OS anyway and not build from source anymore like before. So I'm curious as to what your server used now when using the build command or if it enabled the epel repo again.
Oeps... spoken too soon.
On all servers clamd.scan is running but in DA it's stated as not running. So I stopped it there an started again.
That succeeded after a bit of waiting, but it keeps these processes on all servers:
ps faux | grep clamd@scam
root     2182054  0.0  0.0 1283248 20932 ?       Ssl  16:30   0:00  \_ /usr/local/directadmin/directadmin taskq --syslog
root     2182166  0.0  0.0  25988  3292 ?        S    16:32   0:00  |   \_ sh -c /usr/bin/systemctl restart [email protected]        >/dev/null 2>/de
root     2182168  0.0  0.0  82188  6676 ?        S    16:32   0:00  |       \_ /usr/bin/systemctl restart [email protected]
root     2182117  0.0  0.0 1283248 22640 ?       Ssl  16:31   0:00  \_ /usr/local/directadmin/directadmin taskq --syslog
root     2182167  0.0  0.0  25988  3364 ?        S    16:32   0:00  |   \_ sh -c /usr/bin/systemctl restart [email protected]        >/dev/null 2>/de
root     2182169  0.0  0.0  82188  6828 ?        S    16:32   0:00  |       \_ /usr/bin/systemctl restart [email protected]
root     2182213  0.0  0.0 1283504 19564 ?       Ssl  16:32   0:00  \_ /usr/local/directadmin/directadmin taskq --syslog
root     2182228  0.0  0.0  25988  3440 ?        S    16:32   0:00  |   \_ sh -c /usr/bin/systemctl start [email protected]        >/dev/null 2>/dev/
root     2182229  0.0  0.0  82188  6880 ?        S    16:32   0:00  |       \_ /usr/bin/systemctl start [email protected]
root     2182565  1.0  0.0 1283504 21400 ?       Ssl  16:33   0:00  \_ /usr/local/directadmin/directadmin taskq --syslog
root     2182580  0.0  0.0  25988  3476 ?        S    16:33   0:00      \_ sh -c /usr/bin/systemctl start [email protected]        >/dev/null 2>/dev/
root     2182581  0.0  0.0  82188  6792 ?        S    16:33   0:00          \_ /usr/bin/systemctl start [email protected]
They shouldn't be active right?
And then they stop again.
