Where can I find the Sent Emails menu in Evolution skin?
SupermanInNY
In Enhanced skin, I had the option to set a value for the Sent Emails (daily).
Where can I find this menu in the Evolution skin?
Thanks,
-Sup
Indeed a bit hard to find.
But on the total right side in Evolution you see a + character next to every e-mail address. Click on the + and then you can choose between change username/password and change limits.
I don't have that menu item as you describe.
Yes you do. But you are looking at the wrong place.
You gave the Enhanced example, there you were looking at the e-mails page. So in Evo you should also be looking at the e-mails page, not on the "view users" list.
BUT,.. I found it:
No you found the limit for the user, not for the e-mail addresses. If you want to limit the user, then you are in the right place.
To limit seperate email addresses, don't use admin but user level and look at e-mails.
Screenshot:
Screenshot:
Actually, in my first question I was looking for the admin level limits for the entire account.
You pointed me to the individual mailbox limits.
But, notice my first printscreen was of the 'admin level' control of the daily limits.
Either way,.. I greatly appreciate your assistance and the time you took to help me find this answer - as you actually answered my second question (which I was about to ask, but you beat me to it :))) ).
Really thank you.
You're absolutely right. You're screenshot pointed indeed to the admin section, I was thinking at the wrong place, and you were exactly at the right place which you found.
But glad to read that I temporarily seemed to have had some predictive gift and managed to answer a question you didn't asked yet. :)
You're very welcome, glad to see all is as should be now.
