SupermanInNY
- Sep 28, 2004
Indeed a bit hard to find.Where can I find this menu in the Evolution skin?
Yes you do. But you are looking at the wrong place.I don't have that menu item as you describe.
No you found the limit for the user, not for the e-mail addresses. If you want to limit the user, then you are in the right place.BUT,.. I found it:
Actually, in my first question I was looking for the admin level limits for the entire account.Yes you do. But you are looking at the wrong place.
You gave the Enhanced example, there you were looking at the e-mails page. So in Evo you should also be looking at the e-mails page, not on the "view users" list.
To limit seperate email addresses, don't use admin but user level and look at e-mails.
Screenshot:
You're absolutely right. You're screenshot pointed indeed to the admin section, I was thinking at the wrong place, and you were exactly at the right place which you found.Actually, in my first question I was looking for the admin level limits for the entire account.
