Richard G
Hello.
I don't use rspamd, so it might be SQLight was busy by DA itself, I don't know. However, it's odd that it's a hour long because I these mails from cron for an hour long. First time I've seen this too, while the plugin is running already on the servers for some time.
On the other hand.... I only got them yesterday night first time, and last night I didn't get anything, so if this is run every night, then it seems is indeed has been a conflicting situation as you think.
It's just a bit odd that this conflict is happening on 2 servers on exactly the same time. But maybe some DA cron is running at that time too, which would explain it.
I will report back if it happens again, or if it will happen just once a while, then at least I know I don't need to worry. Thanks!
