DirectSlave/GO 3 - public beta
Unfortunately no, I still have mine running but haven't done anything with it for years. I'm also not using DNSSEC on it.
You don't? Oh because I've seen an old post from you on WHT where you said it worked with DS without issues. Hence my question. :)
Yes I have worked with it in the past, but I dropped it shortly after, I think at that time it was a lot of manual work per domain, when I switched domain registrars I probably removed the ones I had it enabled on. I did a quick look and there was 1 domain still in my /var/named that had a .key file. A domain that no longer is registered. Using dig +dnssec on both the DA server and the DirectSlave server, gives back the RRSIG. So it was succesful at somepoint in transfering that at least. Also I did notice that in my DirectSlave server, in the named_workdir (in etc/directslave.conf), it has all the .db files, but there is no .key file there. Not sure if it actually needs those files on the slave?
Oh LoL yes good question. I know in the DA Multiserver Setup those files are on both servers.
Now you say this I wanted to test but I just moved from nameserver so they are not on the DS server anymore. The domains present there do not have DNSSEC, so I can't test anymore.
If I read correctly only the db.signed files should be present. But I know for a fact they were not.
Maybe @roman_m can enlighten us on this, or fix this when he will be available again.
Some people asked me if I had kind of a manual for it. So @Active8 and @ericosman and whoever is interested, this is how I have it running at the moment.
You need this anyway:
yum install perl-Sys-Syslog
maybe more.
The readme has some errors in it. At least regarding a filename.
named_conf /etc/namedb/secondary/named.conf
While in fact, in the directslave.conf it says:
named_conf /etc/named/directslave.inc
so other name and 1 directory earlier. This last one is the correct location. So I use this location and this filename. Filename will be created automatically, if not, "touch" it and chown to named.
In the /etc/named directory, create a directory called /secondary/ and chown it to named.
When ready, it can be used like this, the directslave.conf (adjust to your needs):
background      1
host            *
port            2222
sslport         2224
ssl             off
ssl_cert        /usr/local/directslave/ssl/fullchain.pem
ssl_key         /usr/local/directslave/ssl/privkey.pem
cookie_sess_id  DS_SESSID
cookie_auth_key 0El2dbMZlwxxxxxxx@)xxxxxxxxxx-THISMUSTBELONGENOUGH!!--xxxxxxx
debug           0
uid             0
gid             0
pid             /usr/local/directslave/run/directslave.pid
access_log      /usr/local/directslave/log/access.log
error_log       /usr/local/directslave/log/error.log
action_log      /usr/local/directslave/log/action.log
named_workdir   /etc/named/secondary
retry_time      300
rndc_path       /usr/sbin/rndc
named_format    text
authfile        /usr/local/directslave/etc/passwd
Also use things from the readme like this command:
/usr/local/directslave/bin/directslave --check
Be aware that rndc is working.
As for the cookie_auth_key, this must be long enough. I've got 65 random characters, but maybe I did wrong but should be 64 anyway if I understood it correctly.
You can see that I use uid and gid 0 here, but it doesn't matter as this is decided by the system start file anyway.
To do that, use this:
/usr/local/directslave/etc/systemd/directslave.service
I presume you know how to make that a starting system file. Copy it over and enable the service. ;)
Now in Directslave vps /etc/named.conf you need this:
        allow-notify { master.server.ip; };
On the master server you need this in the named.conf file:
        allow-transfer { direct.slave.vps.ip; };
Don't forget to restart your named service on master and slave after making changes to the named.conf file.
Now all you need is the connection to Directslave from your DA server.
So use the Directslave binary in the /usr/local/directslave/bin directory to do this.
Use "directslave --password" and "--delete" flags to add, delete and modify users
You should have a passwd file in the /usr/local/directslave/etc directory with a username and password.
Now go into your DA server, use the multi-server setup on port 2222 and enter the username and password you created and check connection. Things should be good now.
I didn't manage to create SSL on the Directslave server, so in my case it's working via 2222.
I use a firewall on my VPS so the webpage of Directslave is only visible to me.
Ofcourse... it's multi server setup and DS needs to know your stuff, so you should paste your DNS files:
echo "action=rewrite&value=named" >> /usr/local/directadmin/data/task.queue
Could take a minute or two. Check your DS logfiles for issues or errors.
Hope it will all work for you. It could be some extra packages in there.
I had issues with Directslave getting it to work with Debian/Ubuntu. Don't know sure in Alma 9. I used Almalinux 8 and in there it works flawlessly.
Let me know if you find issues you can't solve. ;)
There was a Github (not maintained anymore)
Yes I've found that one too last year and seen some old stuff and if I'm correct this was for Debian, right? So I decided that manually was the way to go.
But there is room for improvement I see.. because now you have on both DS and the master server the allow-notify and allow-transfer, which isn't needed on both. :)
Also the script might be foolproof, the readme is not. :D
allow-notify { DirectSlave_IP_server_1, DirectSlave_IP_server_2; };
allow-transfer { DirectSlave_IP_server_1, DirectSlave_IP_server_2; };
If you give examples this way, they should at least be either fully correct, or totally incorrect. These are half correct.
After the DirectSlave_ip_server1 there is a comma in both cases, which should be a dotcomma, so the ; character.;)
Also in both cases is stated:
listen-on-v6 port 53 { none; };
on both the DS and the slave server. However, why should you limit DNS queries to ipv4 if you're using ipv6 too?
I didn't look at all the script, but personally I don't like things like this:
echo "creating user "$1" and adding to wheel"
useradd -G wheel $1 > /root/install.log
echo $2 |passwd $1 --stdin  >> /root/install.log
echo "Disabling root access to ssh use "$1"."
so I don't like that somebody is added to any wheel group without my knowledge and I don't like that root login to SSH is disabled by this script too. Because if you make some mistake, you're out of your server. That makes it non-foolproof.
This should at least be mentioned in the readme!!
Also it makes use of firewalld. So nice for noobs.
Others might prefer CSF/LFD on this server too, but that is a choice.
Questions:
1.) wget -q https://directslave.com/download/directslave-3.2-login-XSS-HOTFIX.tar.gz
Is this still required? Isn't that template also fixed already in the directslave 3.4.3 release?
2.) Why both allow-notify and allow-transfer lines on both servers while only 1 line is required?
3.) cookie_auth_key Change_this_line_to_something_long_&_secure
I don't see this being created in the script, but I also don't see any information on this in the readme, so for sure this will generate errors.
And this one is very very important!
4.) touch /etc/namedb/named.conf
Why? This is a non-existing file and will never exist either.
5.) Is everything working in your case? Because I'm missing this one in the script.
@Richard G feel free to help the project on Github :-) i only forked it and made some small changes (to make it functional), this big stuff you mention i have to read into.
I don't think I've got a personal github account, only alias which I don't want to use. I know you forked it and made small changes, just wanted to help improve.
But you can use my tips here also and just as per pm if something is unclear too, then we can speak in Dutch, easier too. :)
I've done an installation of Directslave but when trying the connection on the multisite page it gives me this error:
I do have a firewall in front of both servers, but even when allowing everything it doesn't work.
How can I debug this?
Check your Directslave logs, and directadmin logs.
But I think the Directslave logs will give you the best insight.
The directslave logs were empty,
I am able to connect via internal ip address. Which is strange because I opened all the ports.
In that case no connection is made.
Via internal ip? Hmmz.. are you also using both internal and external ip's on server and/or VPS, with Transip or something?
Normally not all ports need to be opened, but on both the ports for DNS traffic (udp/tcp 53 and 953 and port 2222 tcp for the DA info).
So if you try via external ip is there anything to see in any of the directadmin logs?
If you indeed use Transip, try disabling the complete Transip firewall and see what happens.
For anyone that is interested, I ported the Centos 7 installer script created by osmannboy on Github to work with Debian 12.
The instructions and script can be accessed on this GitHub Gist. Feel free to suggest improvements. It's taken me a few days of testing and seems to work and even has support for the minimal install of Debian 12.
Bringing this topic up again since I think it's related to the issues in the topic;
I was/(still) am experiencing nameserver-issues (Zones not being transferred to my nameserver) so I tried to update DirectSlave from the current version 3.4.1 to the latest 3.4.3.
Renamed the old DS-dir and installed the new/updated one next to it. Copied the directslave.conf-contents to the new version and renamed the 'amd64'-version to 'directslave', just like the old version had.
But I guess I Fubarred something in the process or didn't do enough steps because now the connection with Master/Slave also stopped working.
I get a "Unable to get API results"-error when testing the connection from DA.
Any pointers at what to look for to fix this?
Ah, did not look so close for the log-files... There I learned that I forgot to copy the 'passwd' file also to the new directory.
I didn't think DS would use a password for anything.
I moved/renamed the original dir (v3.4.1) into directslaveBAK and copied the new version (v3.4.3) into its new dir.:
/usr/local/directslaveBAK
Then copied /usr/local/directslaveBAK/etc/directslave.conf to /usr/local/directslave/etc/
And chown'd recursive all files to bind:bind
Got one step further now, but now the new server is not getting through the authentication on the DS-server.
tried entering the pw in DA mss but it's not working. (I don't recall my old server had a pw to contact the DS-server.)
Yes ofcourse it uses the password for the connection between DA and DS because multiserver setup always uses a password. ;)
Oke that's a password issue. To make life easier, maybe it's best to either create a new multi-server connection on your DA server or change the multi-server password, because your old server also had a password, it does not work without.
Then in DS, create the password by DS (or delete the passwd file first if you are only using 1 server with it).
/usr/local/directslave/bin/directslave --password
and enter the exact same username and password you use for your multi-server connection in DA.
It is possible to use a complete different username and password there. Makes things more secure because this way your DA pass is not compromised if your DS pass would be.
Anyway after doing this you should be able to make the connection again.
P.s. if your DA server has a new ip, don't forget to adjust the named.conf on the DS machine.
  • Like
Reactions: BBM
Thanks Richard, this worked.
I don't know the old DS ww on the current vps (you got this working for me at the time I think), but a new connection is working now.
Things are still not quite right I think.
I have a domain on the new VPS that keeps showing ip's of the old VPS and new VPS at various nameservers around the world. My namservers don't agree on where a domain should be pointing to...
I'm also seeing errors in the action.log of DirectSlave:
"Domain 'domeinnaam.nl' reload forbidden for 'IP-of-Old-VPS'"
Looks like the DS-server has issues talking/syncing to the old VPS. Maybe related to the first issue?
