- Feb 27, 2003
Thanks to contact from OVH, we believe the problem is resolved and all licenses should be functional again. A restart of DirectAdmin from the command line should be sufficient to restore DA.
indeed it is workingThanks to contact from OVH, we believe the problem is resolved and all licenses should be functional again. A restart of DirectAdmin from the command line should be sufficient to restore DA.
Thats why i have a Dedicated server with my own licenseI'm having the same problem with my DA license FALSE expired lockout over at MojoHost Bv, and I just started the vps exactly a week!
Well then Mojohost should solve it for you.DA license FALSE expired lockout over at MojoHost Bv,
