ConfigServer shutting down as of 31st of August 2025
Is there any good alternative for CSF that besides network filtering also does brute force detection and connection tracking/limiting?
Hi, thanks all for updating the community. Can someone add a sticky that we can follow how to maintain the csf. I blocked auto update at version 14.24 and right now custombuild shows available version 15.05. Is it safe to update from custombuild or there are any steps that needed to be taken. I have read the whole thread and still not sure how to proceed.
Yes you really SHOULD update.
Everything after 15.0 is maintained by the DirectAdmin teams. (And also hosted on the CDN of directadmin.)
Custombuilds also turns off auto update now (even though in your case it already is) so it can not be updated maliciously.
Exactly. If i'm right, DA have their own copy/fork of the CSF 15.00 on Github, and release updates to us as the needs change for DirectAdmin. I'm happy updating my CSF installs when DA release another version. I'd be wary of installing any other updated versions from other nefarious sources though unless you trust the code 100%
But looks like the latest DA update reverted it back to official.
Yes it's either or. I would advise to keep using the one DA will be use and keeping up to date.
If you want to use another one, you do have to change CSF=yes to CSF=no in custombuild.
But as said. I would advise against it for now.
Yah, if DA keeps care of it, it will be better.
But I think the attached stuffs should get removed. Taking unnecessary space.
Hi @all,
Good morning.
Question regarding CSF Firewall solution.
I just upgraded my machine from Debian 11 (BullsEye) to Debian 12 (Bookworm) and after the dist-upgrade including a: '
da build all' everything runs smoothly, only the csf firewall is gone/not installed anymore (before it was).
On another Directadmin machine (also Debian 12 (Bookworm) it is still there 'Extra Features'. with version:
ConfigServer Security & Firewall - csf v15.05​
Is there an alternative or can it be reinstalled by hand so I can get it back. Looks like there is an alternative now on: https://aetherinox.github.io/csf-firewall/ but not (yet) integrated in DirectAdmin webinterface or is there a better inbuild solution as a good replacement for this software recommended by DirectAdmin.
Directadmin version installed: 1.695 (latest).
Update channel: Current
Thank you for thinking along with me.
Grtz,
Mek
You can install it from custombuild -> options go to the bottom of the page and there is CSF install option.
