I see no exim.conf changes, what was the issue with the previous release? Or did Exim release another build?
# ls -la /usr/local/directadmin/custombuild/patches/exim_4.99_hold_segfault.patch
-rw-r--r-- 1 root root 12979 Dec 4 06:40 /usr/local/directadmin/custombuild/patches/exim_4.99_hold_segfault.patch
I tried it and unfortunately I can't find the “checkbox” to activate it.
"Note: The isolated FPM is activated only for the user accounts that use jailshell (the Jailed check box in the user configuration page)."Hello,
What are you trying to activate? And what is not working?
Please check and try to update this file:Hello, i've a custom /usr/local/directadmin/data/templates/custom/cust_openlitespeed.CUSTOM.8 with webmail.domain.xx set as default for Roundcube.
After latest DA/Litespeed update any webmail.domain.xx still work but "Let's" is not yet generated on these subdomains, this is also from
/usr/local/directadmin/conf/directadmin.conf:
letsencrypt=1
letsencrypt_disable_renew_after_renew_failure=1
letsencrypt_list=www:mail:ftp:webmail
letsencrypt_list_selected=www:mail:ftp:webmail
letsencrypt_multidomain_cert=3
But discarded in SSL request.
include /etc/openlitespeed/httpd-alias.conf
