I see no exim.conf changes, what was the issue with the previous release? Or did Exim release another build?
# ls -la /usr/local/directadmin/custombuild/patches/exim_4.99_hold_segfault.patch
-rw-r--r-- 1 root root 12979 Dec 4 06:40 /usr/local/directadmin/custombuild/patches/exim_4.99_hold_segfault.patch
I tried it and unfortunately I can't find the “checkbox” to activate it.
"Note: The isolated FPM is activated only for the user accounts that use jailshell (the Jailed check box in the user configuration page)."Hello,
What are you trying to activate? And what is not working?
Please check and try to update this file:Hello, i've a custom /usr/local/directadmin/data/templates/custom/cust_openlitespeed.CUSTOM.8 with webmail.domain.xx set as default for Roundcube.
After latest DA/Litespeed update any webmail.domain.xx still work but "Let's" is not yet generated on these subdomains, this is also from
/usr/local/directadmin/conf/directadmin.conf:
letsencrypt=1
letsencrypt_disable_renew_after_renew_failure=1
letsencrypt_list=www:mail:ftp:webmail
letsencrypt_list_selected=www:mail:ftp:webmail
letsencrypt_multidomain_cert=3
But discarded in SSL request.
include /etc/openlitespeed/httpd-alias.conf
Fixed, many thanks.Please check and try to update this file:
as it is described here (STEP 2):
https://docs.directadmin.com/webser...set-up-webmail-example-com-with-openlitespeed
because 68 line was modified there after release of DA version 1.690:
Could you confirm that it works fine if you downgrade your DA version to 1.689 (stable release) or even older one, like 1.688 ?Did something change in 1.690 with DNS or how multiserver sends dns commands in any way?
Maybe the "Remove duplicate records when deleting a DNS record fix" changed something?
It seems we (see Directslave thread) are experiencing odd behaviour of Directslave. The domain .db file are suddenly not created anymore, domain names are put in the directslave.inc file, but on removal of the domain from the DA server, totally nothing is deleted from the DS server anymore. As if the delete command isn't send over anymore via DNS or something.
Might not be related with DA but it's just odd this we discovered this happening after the 1.690 update or slightly earlier.
da update 88922683f8e8480d51fb8eebf9f57135cdf23902
I rather not go back that far. What is the command to downgrade to 1.689?To get 1.688, you can use such command:
da update stable
https://[HOSTNAME]:2222/evo/admin/updates
Oke going back makes some differences.or do it via DA Panel from here:
updating to directadmin - - 88922683f8e8480d51fb8eebf9f57135cdf23902
directadmin - - 88922683f8e8480d51fb8eebf9f57135cdf23902: does not exist
Will do that but might be hard to reach as he's from Ukraine which is at war. He might be soldier.try contacting developers of DirectSlave
zone "eventesten.nl" { type slave; file "/etc/dsnamed/secondary/eventesten.nl.db"; masters { 88.xxx.xxx.xxx.xxx; }; max-retry-time 300; min-retry-time 300; masterfile-format text; };
