Thank you, I will look at that.I think can run , but you can try:
Hi all!
I’m alive and relatively well.
Get ready -- I'm cooking up something amazing for you!
DirectSlave 4, featuring an integrated secondary authoritative DNS server with DNSSEC and NSEC3 support, plus an extended dashboard and detailed statistics.
The release is almost here -- I'm now putting it through final testing in my production environment.
For new DirectSlave/GO 3 public beta see this thread --...
- roman_m
- Forum: 3rd Party Software
Works well and without a license![]()
Thank you for that.It should do. I only specified a 2GB server on my tutorial as I use Hetzner as my main upstream servers and DNS and their smallest VPS is a 2GB one. I did do a tutorial for quick install if that helps also.
Evening all, I've seen a few threads about past week or so and DirectSlave has popped up a few times but some users aren't sure about it or how to use it. I use it, and with a script wrote by @ericosman [THANK YOU!!] on GitHub, it's been made a whole lot easier. I've added in SSL Certificate for secure transfers, and explained a bit further about other bits as the install progresses.
Requirements: Any web server 1 CPU+, 2GB ram recommended, Alma Linux [I'm using Alma Linux 9 for this tutorial, an x86 Server, 2vCPU and 4GB ram, 40GB SSD and use 3 of the same for my real world DNS...
- DrWizzle
- Forum: Installation / System Requirements
I have it running on 1 core 756 MB server and still have many resources leftI only specified a 2GB server on my tutorial as I use Hetzner as my main upstream servers and DNS and their smallest VPS is a 2GB on
That's good to know, thank you!I have it running on 1 core 756 MB server and still have many resources left![]()
