Will personal plus, used only as dns cluster, run on 1gb vps?
mejay
Will personal plus, used only as a dns cluster, run on 1gb vps? My full/standard is on a much larger server, but I want to run personal for redundant dns.
I think can run , but you can try:
Works well and without a license :)
It should do. I only specified a 2GB server on my tutorial as I use Hetzner as my main upstream servers and DNS and their smallest VPS is a 2GB one. I did do a tutorial for quick install if that helps also.
Thank you, I will look at that.
Thank you for that.
