Directadmin's RAM usage
LawsHosting
London UK
Is it normal for it to use gigs of RAM? Hovers around 5Gig.
(I've compared MySQL, as it's the most used)
No, I don't think so. I have checked several servers, and they are from 160 to 500MB
I restarted and instantly went to ~750MB, and climbing......
Here is a log snippet:
28/9/2026 22:13:11    finished task duration=24.208726ms task=action=service-watchdog
28/9/2026 22:13:11    executing task task=action=service-watchdog
28/9/2026 22:13:11    finished task duration=5.51921ms task=action=ssl&value=admin_ssl
28/9/2026 22:13:11    executing task task=action=ssl&value=admin_ssl
28/9/2026 22:12:11    finished task duration=25.378017ms task=action=service-watchdog
28/9/2026 22:12:11    executing task task=action=service-watchdog
28/9/2026 22:12:11    finished task duration=6.52196ms task=action=ssl&value=admin_ssl
28/9/2026 22:12:11    executing task task=action=ssl&value=admin_ssl
28/9/2026 22:11:34    license updated successfully
Is this every-minute task normal?
A few extra notes to add:
* I have the session timeout duration set to 1 week - due to only me using the whole VPS and needing to use phpmyadmin a lot;
* I am logged into my DA account via the Impersonate option in admin;
The host above that was at 9GB RAM usage for DirectAdmin, was updated 2 days ago and is now at 10GB RAM usage.
After restarting it uses 104MB. I'm going to put a restart every 12 hours in the crontab as a workaround.
