28/9/2026 22:13:11 finished task duration=24.208726ms task=action=service-watchdog
28/9/2026 22:13:11 executing task task=action=service-watchdog
28/9/2026 22:13:11 finished task duration=5.51921ms task=action=ssl&value=admin_ssl
28/9/2026 22:13:11 executing task task=action=ssl&value=admin_ssl
28/9/2026 22:12:11 finished task duration=25.378017ms task=action=service-watchdog
28/9/2026 22:12:11 executing task task=action=service-watchdog
28/9/2026 22:12:11 finished task duration=6.52196ms task=action=ssl&value=admin_ssl
28/9/2026 22:12:11 executing task task=action=ssl&value=admin_ssl
28/9/2026 22:11:34 license updated successfully
ThanksIs it normal for it to use gigs of RAM? Hovers around 5Gig.
(I've compared MySQL, as it's the most used)
Does the excessive memory usage only shows up in system services GUI, or does `ps o comm,rss -C directadmin` show similar numbers?The host above that was at 9GB RAM usage for DirectAdmin, was updated 2 days ago and is now at 10GB RAM usage.
In services it now shows up as using 4,91GB after 10 hours.Does the excessive memory usage only shows up in system services GUI, or does `ps o comm,rss -C directadmin` show similar numbers?
# top
top - 10:03:23 up 3 days, 11:33, 1 user, load average: 0.69, 0.56, 0.58
Tasks: 194 total, 1 running, 193 sleeping, 0 stopped, 0 zombie
%Cpu(s): 5.2 us, 2.2 sy, 0.0 ni, 91.8 id, 0.0 wa, 0.0 hi, 0.8 si, 0.0 st
MiB Mem : 19996.7 total, 2198.6 free, 3433.0 used, 15191.8 buff/cache
MiB Swap: 11444.0 total, 11304.0 free, 140.0 used. 16563.7 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
737682 xxxxxd01 20 0 386224 78516 63028 S 10.3 0.4 0:16.43 php-fpm
655806 root 20 0 4276772 194392 48432 S 5.3 0.9 4:16.70 directadmin
642 message+ 20 0 9436 4668 3860 S 3.0 0.0 8:52.81 dbus-daemon
897 mysql 20 0 2616636 411168 13784 S 3.0 2.0 327:56.85 mysqld
# ps o comm,rss -C directadmin
COMMAND RSS
directadmin 177448
directadmin 27972
directadmin 30016
# systemctl show directadmin.service --property MemoryCurrent
MemoryCurrent=5307293696
# cat /sys/fs/cgroup/system.slice/directadmin.service/memory.stat
anon 129265664
file 4929630208
kernel 214556672
kernel_stack 737280
pagetables 1904640
sec_pagetables 0
percpu 9984
sock 0
vmalloc 0
shmem 0
zswap 0
zswapped 0
file_mapped 434176
file_dirty 4096
file_writeback 0
swapcached 4763648
anon_thp 77594624
file_thp 0
shmem_thp 0
inactive_anon 145555456
active_anon 27406336
inactive_file 4552691712
active_file 376938496
unevictable 0
slab_reclaimable 211110880
slab_unreclaimable 719760
slab 211830640
workingset_refault_anon 639
workingset_refault_file 808815
workingset_activate_anon 578
workingset_activate_file 436869
workingset_restore_anon 0
workingset_restore_file 28695
workingset_nodereclaim 0
pgscan 1579049
pgsteal 1512352
pgscan_kswapd 1579049
pgscan_direct 0
pgsteal_kswapd 1512352
pgsteal_direct 0
pgfault 5791411
pgmajfault 454
pgrefill 35203
pgactivate 13156
pgdeactivate 35203
pglazyfree 0
pglazyfreed 0
zswpin 0
zswpout 0
thp_fault_alloc 5821
thp_collapse_alloc 148
memory.stat and memory.current data before and after running the equivalent of echo 3 > /proc/sys/vm/drop_caches : echo "10G" > /sys/fs/cgroup/system.slice/directadmin.service/memory.reclaim (use at your own risk)You are probably worrying too much.Just on time as in about 20 minutes the service will restart and we have to wait again a bit for the memory to build up.
So in services it is now listed as 4.99GB
and..Bash:# systemctl show directadmin.service --property MemoryCurrent MemoryCurrent=5307293696
Bash:# cat /sys/fs/cgroup/system.slice/directadmin.service/memory.stat anon 129265664 file 4929630208 kernel 214556672 kernel_stack 737280 pagetables 1904640 sec_pagetables 0 percpu 9984 sock 0 vmalloc 0 shmem 0 zswap 0 zswapped 0 file_mapped 434176 file_dirty 4096 file_writeback 0 swapcached 4763648 anon_thp 77594624 file_thp 0 shmem_thp 0 inactive_anon 145555456 active_anon 27406336 inactive_file 4552691712 active_file 376938496 unevictable 0 slab_reclaimable 211110880 slab_unreclaimable 719760 slab 211830640 workingset_refault_anon 639 workingset_refault_file 808815 workingset_activate_anon 578 workingset_activate_file 436869 workingset_restore_anon 0 workingset_restore_file 28695 workingset_nodereclaim 0 pgscan 1579049 pgsteal 1512352 pgscan_kswapd 1579049 pgscan_direct 0 pgsteal_kswapd 1512352 pgsteal_direct 0 pgfault 5791411 pgmajfault 454 pgrefill 35203 pgactivate 13156 pgdeactivate 35203 pglazyfree 0 pglazyfreed 0 zswpin 0 zswpout 0 thp_fault_alloc 5821 thp_collapse_alloc 148
There's two other directadmin hosts were this does not happen. So something environment specific is causing this.
A few more notes.
- debian 12 bookworm
- directadmin 1.712 (117d8a4b5586c5533c5dd78ce0d1ae1ea356f586)
- legacy license (on all of them)
All hosts are on PHP8.3 as default using php-fpm.
Things only on this host are:
- PHP 8.1 (set as PHP4 in custombuild)
- proftpd (can be disabled, don't think anyone is using ftp anymore)
- notifications is enabled
- composer
- php_redis (have this on another host as well directadmin on that host is 1.3GB now after 4 days, but it might be differently configured, can check if php_redis is a suspect)
- php_imap
top -o %MEM
