Critical PHP updates
We will be releasing patches for older PHP versions and a fix for PHP 8.1 compilation soon. We have them working but still running some tests.
Thank you! Succes, en sterkte, as we would say in Dutch :)
And now hearing that the patch doesn't completely fix the issue.
Or maybe it's a different similar exploit. Hearing that PHP 8.5.12 is vulnerable.
Anybody having issues with imagick? It seems to compile, but stay visible as an update in custombuild, and wordpress complains it's not available.
Error: Failed to download metadata for repo 'epel': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
executing 'dnf --quiet --assumeyes install gcc-c++ make autoconf pkgconfig openssl-devel systemd-devel krb5-devel libcurl-devel libpng-devel freetype-devel libwebp-devel libjpeg-devel libxslt-devel libsodium-devel libicu-devel sqlite-devel oniguruma-devel libffi-devel libtool-ltdl-devel libzip-devel' failed (attempt 1/3)
executing 'dnf --quiet --assumeyes install gcc-c++ make autoconf pkgconfig openssl-devel systemd-devel krb5-devel libcurl-devel libpng-devel freetype-devel libwebp-devel libjpeg-devel libxslt-devel libsodium-devel libicu-devel sqlite-devel oniguruma-devel libffi-devel libtool-ltdl-devel libzip-devel' failed (attempt 2/3)
It's legacy license
Scan your logs
zgrep -hiE 'php2shell|109618|109619' \
/var/log/nginx/domains/*.log* \
/var/log/httpd/domains/*.log* 2>/dev/null
zgrep -hiE 'auto_prepend_file|php://input|allow_url_include' \
Scan your logs
Thanks, what should I do now.
149.102.239.83 - - [21/Oct/2026:14:27:52 +0200] "GET / HTTP/1.1" 301 4861 "-" "php2shell-checker/3.0 (authorized-scan)"
149.102.239.83 - - [21/Oct/2026:14:27:52 +0200] "GET / HTTP/1.1" 200 46619 "-" "php2shell-checker/3.0 (authorized-scan)"
149.102.239.83 - - [21/Oct/2026:14:27:53 +0200] "POST / HTTP/1.1" 200 46852 "-" "php2shell-checker/3.0 (authorized-scan)"
213.152.161.54 - - [21/Oct/2026:13:34:50 +0200] "HEAD / HTTP/1.1" 200 4832 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 php2shell-probe"
213.152.161.54 - - [21/Oct/2026:13:45:35 +0200] "POST / HTTP/1.1" 200 99124 "-" "Mozilla/5.0 php2shell-sidfix"
I don't want to be rude, but seriously, CentOS 7 is so outdated that you could do already an in-place upgrade to Almalinux.
You're absolutely right, and I completely agree. However, these servers won't be in use much longer, so upgrading the OS isn't really worth the time and effort.
I'm just looking for a temporary way to keep PHP patched and secure in the meantime.
I have been able to compile a patched version of php7.4 on almalinux servers but not on centos7 servers, it just downloads the latest php7.4 without the patch. Any suggestions on how to get this patached on centos7?
We have heard that it has not been fully patched. Does anyone have more information on whether this is real and correct?, see below.
Looks like a separate memory bug, not yet fixed, that a specific PHP function triggers when a script calls it in a certain way. It isn't shown to be reachable through a simple web request.
