Thank you! Succes, en sterkte, as we would say in DutchWe will be releasing patches for older PHP versions and a fix for PHP 8.1 compilation soon. We have them working but still running some tests.
zgrep -hiE 'php2shell|109618|109619' \
/var/log/nginx/domains/*.log* \
/var/log/httpd/domains/*.log* 2>/dev/null
zgrep -hiE 'auto_prepend_file|php://input|allow_url_include' \
Were you able to download it? There’s nothing new in my yum.So far, CloudLinux have finished basically 1x version for many distros - PHP v7.4.
Thanks, what should I do now.Scan your logs
Code:zgrep -hiE 'php2shell|109618|109619' \ /var/log/nginx/domains/*.log* \ /var/log/httpd/domains/*.log* 2>/dev/null
Code:zgrep -hiE 'auto_prepend_file|php://input|allow_url_include' \ /var/log/nginx/domains/*.log* \ /var/log/httpd/domains/*.log* 2>/dev/null
You're absolutely right, and I completely agree. However, these servers won't be in use much longer, so upgrading the OS isn't really worth the time and effort.I don't want to be rude, but seriously, CentOS 7 is so outdated that you could do already an in-place upgrade to Almalinux.
Looks like a separate memory bug, not yet fixed, that a specific PHP function triggers when a script calls it in a certain way. It isn't shown to be reachable through a simple web request.We have heard that it has not been fully patched. Does anyone have more information on whether this is real and correct?, see below.
Are you planning any updates or patches for CentOS 7.9? Many of us are still running it with DirectAdmin, and it would be helpful to know if any compatibility fixes or security updates are planned.A new build is released. It includes patches for older PHP versions (7.3, 7.2, 7.1, 7.0, 5.6) and also a small fix for the PHP 8.1 compilation.
