For that question you need to be at cPanel/WHM forum, not here. SorryWhere in the cpanel/whm do I locate the reseller level backup option?
Try to rename the file to: lhent.tar.gz and then run the process.
Use Reseller level backups and process them. Not the user level.
If I were to supply my cpanel backup, can someone transfer it to the DA format? I have tried many different things and it keeps failing.
SupermanInNY said:djmessy said:Did you receive the FTP details I sent yesterday?
Yes, I did.
At first I thought you have only 100MB of size.
Then it turns to be a really big backup file - 1GB in size.
So it took a very long time to d/l onto my server.
I then ran the regular import process and same as with you, it failed.
I tried different options, but no success.
Possible solutions to run:
Use a different da.cpanel.conversion tool. I think there are two versions out there. I'm not sure which version I'm using.
If that doesn't work, then reduce the size of the backup to the smallest.
Don't backup the public_html directory. The Public Html directory can be backed up separartly.
So if you can backup the cPanel without the homedir, then do that.
This will allow the creation/work with a smaller size file and will have all your work available quickly.
The 'missing' piece of the public_html can be just pulled out from the current full backup and restored via tar into an active DirectAdmin account.
Can you do the small backup?
-Alon.
INSTRUCTIONS
1/ Download and extract the version URL (from above) that you wish to use. (wget and tar xzf)
2/ Create import and export directories for the tool to use. (mkdir import export)
3/ Copy your cPanel user backups into the import directory.
4/ Edit defaults.conf to match the DA server you will be restoring to. The only fields you must change are the IP and name server fields. The tool will not work if you fail to do this!
5/ Execute perl da.cpanel.import.pl and follow the on-screen instructions (which will duplicate the steps here to a degree).
6/ After the tool is finished converting (or as it completes each individual user), move your new DA user backups from the export directory to any DA /home/RESELLER/user_backups directory*
7/ Restore the DA user backups in DA's reseller-level Manage User Backups tool.
That's it!
*If the tool is being executed on a cPanel server, you can optionally have the tool automatically transfer your new DA user backups (after all conversion is complete) to a remote server.
Unable to extract backup/user.conf from /home/admin/user_backups/chaos.tar.gz : Error while extracting backup/user.conf to /home/admin/user_backups/chaos as admin : /bin/tar: backup/user.conf: Not found in archive
/bin/tar: Error exit delayed from previous errors
Cannot read /home/admin/user_backups/chaos/backup/user.conf : Unable to open /home/admin/user_backups/chaos/backup/user.conf for reading
