jlasman said:I'm not sure if editing quotas will cause any problems; certainly it won't if command line editing of quotas won't.
The max quotas shown in the panel are in the DA user configs.... the disk quotas are there to simply force them quotas as an actual limit...
so you could modify the disk quotas and it would allow overages etc, later causing problems when you have accounts in DA showing used/max 150/100
Sendmail, yes its common sense, although you must consider the fact users with little knowledge of DA may go playing, reenabling sendmail etc etc... you get the idea
If you don't do anything with webmin you wouldn't do from the command line you should be okay.
Totally disagree. With the command line you dont have a list of menus with nifty little options that make you think "hmmm do I try this"
Chris
