Custom Apache Build System
Failed to make
With the new version, I'm getting a failed to make error. Any ideas?
<=== src/modules/ssl
===> src/modules/frontpage
/bin/sh: line 1: cd: frontpage: No such file or directory
make[3]: *** [all] Error 1
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/usr/local/directadmin/customapache/apache_1.3.31/src'
make[1]: *** [build-std] Error 2
make[1]: Leaving directory `/usr/local/directadmin/customapache/apache_1.3.31'
make: *** [build] Error 2
*** The make has failed, do you want to try to make again? (y,n):
Is there any possibility of having customapache also install turk mmcache? Since its about the same as zend and needs to be installed before zend it would be a nice addition to the system. :)
Re: Failed to make
This qualifies as a problem.
I don't know but, are you sure all stuff is downloaded ? (frontpage .tar.gz file?)
I haven't had the time to recompile here, but i'll give it a shot in the weekend :D
You might be using a really old configure.apache_ssl file. Try deleting it, then run "./build update" again, then try to compile it.
Can you please add ModGzip to that list of software that are automatically installed ? Even if it's adding another seperate command like build zend.
The reason that I've asked is that I've tried to install it using the guide provided on the DA forum, and I got an error. I had to remove the httpd.conf and then rebuild everything.
just updated, but httpd restart gives me this:
Stopping httpd: [ OK ]
Starting httpd: [Mon Jun 14 15:19:51 2004] [warn] module perl_module is already loaded, skipping
[ OK ]
You can ignore it, but if you want to fix you should find duplicates of:
<IfDefine HAVE_PERL>
LoadModule perl_module modules/libperl.so
</IfDefine>
within the httpd.conf
Chris
its there twice:
</IfDefine>
LoadModule frontpage_module /usr/lib/apache/mod_frontpage.so
LoadModule perl_module /usr/lib/apache/libperl.so
and
</IfDefine>
Just comment out one of them..
#LoadModule perl_module /usr/lib/apache/libperl.so
Chris
when i run phpinfo(); to see some info on php, i see:
Client API version 3.23.49??
[root@server01 admin]# mysql -V
mysql Ver 12.22 Distrib 4.0.18, for pc-linux (i686)
is that a problem?
When I do: ./build zend I get:
[root@rotterdam customapache]# ./build zend
File already exists: .tar.gz
gzip: stdin: unexpected end of file
tar: Kind retourneerde status 1
tar: Fout afsluiting uitgesteld na eerdere fouten
Location of php.ini:
/usr/local/lib
Press return to continue...
./build: line 1266: ./install.sh: Onbekend bestand of map
How to fix it?
Looks like you have a half downloaded zend file. Delete the empty/partially downloaded zend tar.gz file and then run:
./build update_data
./build zend
