Arieh
Arieh, are you sure is needed the slave's bind named.conf change?
I don't have that change and everything is working fine on my side
Regards
Yes you're right, allow-transfer specifies slaves, DA server obviously isn't a slave.
Regards
Nothing changed.
But just to make sure I'm changing /etc/named.conf.
File /etc/named/secondary/named.conf is still empty.
named[123456]: zone example.com/IN: loaded serial 2016071801
Jul 19 21:14:01 ns2 named[1821]: client 79.100.100.100#55386: received notify for zone 'da.poltel.com'
Jul 19 21:14:01 ns2 named[1821]: zone da.poltel.com/IN: Transfer started.
Jul 19 21:14:01 ns2 named[1821]: transfer of 'da.e-poltel.com/IN' from 79.100.100.100#53: connected using 79.100.100.102#35190
Jul 19 21:14:01 ns2 named[1821]: zone da.poltel.com/IN: transferred serial 2016071902
Jul 19 21:14:01 ns2 named[1821]: transfer of 'da.e-poltel.com/IN' from 79.100.100.100#53: Transfer completed: 1 messages, 12 records, 334 bytes, 0.001 secs (334000 bytes/sec)
Jul 19 21:14:01 ns2 named[1821]: zone da.poltel.com/IN: sending notifies (serial 2016071902)
Jul 19 21:14:01 ns2 named[1821]: dumping master file: /etc/named/secondary/tmp-ZK7YHjDsZ0: open: permission denied
andchown -R root:named /etc/named
chmod 755 /etc/named/secondary/
chown named:named /etc/named/secondary/
chmod -R 755 /etc/named
I didn't personally tested yet, but i think i've read of someone that used it on CentOS 7, maybe you should give it a try.
Best regards
You need a Server to run DirectSlave, and that server shouldn't have DirectAdmin on it.
You may need to clarify here or in the other post what is your goal, if you want to set your own secondary DNS Server or if you want to use OVH Slave DNS Server service.
Is not really clear so far what it is your goal.
Best regards
checking domain.com existance from 1xx.70.9x.x: not exist with owner none
1xx.70.9x.x have no permission to remove blabla.sla.pl owned by none
Looks to me there are owner issues. If you are running Directslave as user "named" (for example), the files should be owned and created by user named.not exist with owner none
