Hi all,
I did an reinstall because i messed up my system. I did remember that I spent 3 days with the install so i kept an log of what i was doing.
This turned out to be an bash script which does the following from an clean
Centos 6 system:
- Update all
- Add an new user an disable root login on ssh
- Install all the nessecary perl modules
- Install DS, named and fail2ban
- config it all together (no ssl for DS, fail2ban jails: SSH, Named en DA, Iptables basic sets, named to function as slave), named als slave
- adding startup script and do the chkconfig settings
Save it to any kind of sh file.
Chmod to 777
run it (when calling the script you have to put some arguments: <username> <password> <ip of master>)
delete it
It's my first bash script, so feedback is always welcome.
Here it is...
#!/bin/sh
if [ -z "$1" ]; then
echo "useage <username> <userpass> <master ip>";
exit 0;
fi
if [ -z "$2" ]; then
exit 0;
fi
if [ -z "$3" ]; then
exit 0;
fi
echo "Saving most outputs to /root/install.log";
echo "doing updates and installs"
yum update -y > /root/install.log
yum install epel-release -y >> /root/install.log
yum install bind fail2ban perl-Time-HiRes.x86_64 -y >> /root/install.log
service named start >> /root/install.log
service named stop >> /root/install.log
echo "creating user "$1" and adding to wheel"
useradd -G wheel $1 > /root/install.log
echo $2 |passwd $1 --stdin >> /root/install.log
echo "disable root acces to ssh"
sed -i '/PermitRootLogin/ c\PermitRootLogin no' /etc/ssh/sshd_config
service sshd restart >> /root/install.log
echo "ïnstalling perl modules"
cd ~
wget -q http://www.cpan.org/authors/id/R/RS/RSAVAGE/Crypt-PasswdMD5-1.40.tgz >> /root/install.log
tar -xf Crypt-PasswdMD5-1.40.tgz
cd Crypt-PasswdMD5-1.40
perl Makefile.PL
make >> /root/install.log
make test >> /root/install.log
make install >> /root/install.log
cd ~
wget -q http://www.cpan.org/authors/id/B/BI/BINGOS/Config-Auto-0.44.tar.gz >> /root/install.log
tar -xf Config-Auto-0.44.tar.gz
cd Config-Auto-0.44
perl Makefile.PL
cd ~
wget -q http://www.cpan.org/authors/id/R/RH/RHANDOM/Net-Server-2.008.tar.gz >> /root/install.log
tar -xf Net-Server-2.008.tar.gz
cd Net-Server-2.008
perl Makefile.PL
cd ~
wget -q http://www.cpan.org/authors/id/M/MR/MRSAM/Net-CIDR-0.18.tar.gz >> /root/install.log
tar -xf Net-CIDR-0.18.tar.gz
cd Net-CIDR-0.18
perl Makefile.PL
echo "installing and confugrating directslave"
cd ~
wget -q http://regme.in/download/directslave-2.1-beta.tar.gz >> /root/install.log
tar -xf directslave-2.1-beta.tar.gz
mv directslave /usr/local/
cd /usr/local/directslave
chown named:named -R /usr/local/directslave
cp /usr/local/directslave/etc/directslave.conf /usr/local/directslave/etc/directslave.conf.copy
sed -i '/background/ c\background 1' /usr/local/directslave/etc/directslave.conf
sed -i '/uid/ c\uid named' /usr/local/directslave/etc/directslave.conf
sed -i '/gid/ c\gid named' /usr/local/directslave/etc/directslave.conf
sed -i '/^ssl on$/ c\ssl off' /usr/local/directslave/etc/directslave.conf
sed -i '/^debug/ c\debug 0' /usr/local/directslave/etc/directslave.conf
#mkdir /etc/namedb
mkdir -p /etc/namedb/secondary
touch /etc/namedb/secondary/named.conf
chown named:named -R /etc/namedb
echo "preparing named for jail2ban"
mkdir /var/log/named
touch /var/log/named/security.log
chmod a+w -R /var/log/named
echo "
// named.conf
// Provided by Red Hat bind package to configure the ISC BIND named(8) DNS
// server as a caching only nameserver (as a localhost DNS resolver only).
// See /usr/share/doc/bind*/sample/ for example named configuration files.
options {
listen-on port 53 { any; };
listen-on-v6 port 53 { any; };
directory \"/var/named\";
dump-file \"/var/named/data/cache_dump.db\";
statistics-file \"/var/named/data/named_stats.txt\";
memstatistics-file \"/var/named/data/named_mem_stats.txt\";
allow-query { any; };
allow-recursion { none; };
allow-notify { "$3"; };
allow-transfer { none; };
dnssec-enable yes;
dnssec-validation yes;
/* Path to ISC DLV key */
bindkeys-file \"/etc/named.iscdlv.key\";
managed-keys-directory \"/var/named/dynamic\";
logging {
channel security_file {
file \"/var/log/named/security.log\" versions 3 size 30m;
severity dynamic;
print-time yes;
category security {
security_file;
channel default_debug {
file \"data/named.run\";
severity dynamic;
zone \".\" IN {
type hint;
file \"named.ca\";
include \"/etc/named.rfc1912.zones\";
include \"/etc/named.root.key\";
include \"/etc/namedb/directslave.conf\";
" > /etc/named.conf
/usr/local/directslave/bin/pass $1 $2
/usr/local/directslave/bin/directslave --check >> /root/install.log
rm /usr/local/directslave/run/directslave.pid
echo "setting basic iptables"
service iptables stop >> /root/install.log
iptables -P INPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -P OUTPUT ACCEPT
iptables -F
iptables -N LOGGING
iptables -A INPUT -i lo -j ACCEPT
iptables -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 2222 -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 53 -j ACCEPT
iptables -A INPUT -p udp -m udp --dport 53 -j ACCEPT
iptables -A INPUT -j LOGGING
iptables -A LOGGING -m limit --limit 2/min -j LOG --log-prefix "IPTables-Dropped: "
iptables -A LOGGING -j DROP
iptables -P INPUT DROP
iptables -P FORWARD DROP
service iptables save >> /root/install.log
echo "install and configure fail2ban"
cp /etc/fail2ban/jail.conf /etc/fail2ban/jail.local
sed -i '/^\[sshd\]/ a enabled = true' /etc/fail2ban/jail.local
sed -i '/\[sshd-ddos\]/ a enabled = true' /etc/fail2ban/jail.local
sed -i '/\[selinux-ssh\]/ a enabled = true' /etc/fail2ban/jail.local
sed -i '/\[named-refused\]/ a enabled = true' /etc/fail2ban/jail.local
sed -i '/\[directadmin\]/ a enabled = true' /etc/fail2ban/jail.local
sed -i '/logpath = \/var\/log\/directadmin\/login.log/ c\logpath = /usr/local/directslave/log/access.log' /etc/fail2ban/jail.local
echo "building directslave service"
echo "
#!/bin/sh
# directslave daemon Start/Stop/Status/Restart
# chkconfig: 2345 80 20
# description: Allow you to use DirectAdmin Multi-Server function \
# without need to have a DirectAdmin license, \
# for manage external DNS Server.
# processname: directslave
# config: /usr/local/directslave/etc/directslave.conf
# pidfile: /usr/local/directslave/run/directslave.pid
# Source function library
. /etc/rc.d/init.d/functions
PROGBIN=\"/usr/local/directslave/bin/directslave --run\"
PROGLOCK=/var/lock/subsys/directslave
PROGNAME=directslave
#check the command line for actions
start() {
echo -n \"Starting DirectSlave: \"
daemon \$PROGBIN
echo
touch \$PROGLOCK
stop() {
echo -n \"Stopping DirectSlave: \"
killproc \$PROGNAME
echo
rm -f \$PROGLOCK
reload() {
echo -n \"Reloading DirectSlave config file: \"
killproc \$PROGNAME -HUP
echo
case \"\$1\" in
start)
start
stop)
stop
status)
status $PROGNAME
restart)
stop
start
reload)
reload
echo \"Usage: \$1 {start|stop|status|reload|restart}\"
exit 1
esac
exit 0
" > /etc/rc.d/init.d/directslave
echo "setting chkconfig and starting up"
chown root:root /etc/rc.d/init.d/directslave
chmod 755 /etc/rc.d/init.d/directslave
chkconfig --add directslave
chkconfig --level 2345 directslave on
chkconfig --level 345 fail2ban on
chkconfig iptables on
chkconfig --level 345 named on
service iptables restart >> /root/install.log
service fail2ban start >> /root/install.log
service named restart >> /root/install.log
service directslave restart >> /root/install.log
echo "all done!"
exit 0;
