SeLLeRoNe
Super Moderator
Probably you're not using PHP 5.5, latest phpMyAdmin works with PHP 5.5 or higher.
Regards
Regards
Regards
#PHP Settings
php1_release=5.6
php1_mode=suphp
php2_release=no
php2_mode=php-fpm
opcache=yes
htscanner=no
php_ini=no
php_timezone=Europe/Amsterdam
php_ini_type=production
ioncube=yes
zend=no
suhosin=yes
x_mail_header=yes
#MySQL Settings
mysql=5.6
mysql_inst=mariadb
mysql_backup=yes
mysql_backup_dir=/usr/local/directadmin/custombuild/mysql_backups
mysql_force_compile=no
#WEB Server Settings
webserver=apache
modsecurity=no
modsecurity_ruleset=comodo
apache_ver=2.4
apache_mpm=auto
mod_ruid2=no
harden_symlinks_patch=yes
use_hostname_for_alias=no
redirect_host=vps002.variety-productions.nl
redirect_host_https=no
#WEB Applications Settings
phpmyadmin=yes
phpmyadmin_ver=4
squirrelmail=no
roundcube=yes
webapps_inbox_prefix=no
#ClamAV-related Settings
clamav=yes
clamav_exim=yes
modsecurity_uploadscan=no
proftpd_uploadscan=no
pureftpd_uploadscan=no
suhosin_php_uploadscan=no
#Mail Settings
exim=yes
eximconf=yes
eximconf_release=4.3
blockcracking=yes
easy_spam_fighter=yes
spamassassin=yes
dovecot=yes
dovecot_conf=yes
pigeonhole=no
#FTP Settings
ftpd=proftpd
#Statistics Settings
awstats=no
webalizer=yes
#CustomBuild Settings
custombuild=2.0
autover=yes
bold=yes
clean=yes
cleanapache=yes
clean_old_tarballs=yes
clean_old_webapps=yes
downloadserver=files6.directadmin.com
#Cronjob Settings
cron=yes
cron_frequency=daily
[email protected]
notifications=yes
da_autoupdate=yes
updates=no
webapps_updates=no
#CloudLinux Settings
cloudlinux=no
cagefs=no
#Advanced Settings
autoconf=yes
automake=yes
libtool=yes
curl=yes
new_pcre=yes
sa_update=daily
litespeed_serialno=trial
mariadb=10.1
Build process in progress. PID: 2531 (kill) Started from terminal.
[root@srv ~]# ps
PID TTY TIME CMD
1249 pts/0 00:00:00 bash
15557 pts/0 00:00:00 ps
Hi, i've this message from hours:
HTML:Build process in progress. PID: 2531 (kill) Started from terminal.
but there is not any 2531 pid.
HTML:[root@srv ~]# ps PID TTY TIME CMD 1249 pts/0 00:00:00 bash 15557 pts/0 00:00:00 ps
Any help?
kill -9 2531
[root@srv ~]# kill -9 2531
-bash: kill: (2531) - No such process
[root@srv ~]# cd /usr/local/directadmin/custombuild
[root@srv custombuild]# ls
all_locales-1.4.18-20090526.tar.gz libtool-2.4.5.tar.gz
apr-1.5.2.tar.gz libxml2-2.9.3.tar.gz
apr-util-1.5.4.tar.gz libxslt-1.1.28.tar.gz
autoconf-2.68.tar.gz m4-1.4.17.tar.gz
automake-1.15.tar.gz Mail-SpamAssassin-3.4.1.tar.gz
build mhash-0.9.9.9.tar.gz
configure mod_aclr2-1.0.0.tar.gz
curl-7.46.0.tar.gz mod_ruid2-0.9.8.tar.bz2
custombuild.log nghttp2-1.3.4.tar.gz
dovecot-2.2.21.tar.gz nginx-1.8.0.tar.gz
dovecot.boot nginx.boot
dovecot.boot.debian nginx.boot.debian
dovecot.boot.freebsd nginx.boot.freebsd
dovecot.conf options.conf
dovecot.logrotate patches
exim-4.86.tar.gz patches_versions.txt
exim_boot pcre-8.20.tar.gz
exim.conf.dovecot.patch php-5.4.45.tar.gz
exim_debian php-5.5.30.tar.gz
exim_freebsd phpMyAdmin-4.5.2-all-languages.tar.gz
freetype-2.6.2.tar.gz pure-ftpd
harden-symlinks-2.4.patch pure-ftpd-1.0.42.tar.gz
httpd_2 pure-ftpd_debian
httpd-2.4.18.tar.gz pure-ftpd_freebsd
httpd_2_debian roundcubemail-1.1.3.tar.gz
httpd_2_freebsd servers.txt
icu4c-4_8_1_1-src.tgz squirrel_logger-2.3.1-1.2.7.tar.gz
jpegsrc.v6b.tar.gz squirrelmail-1.4.23-20150507_0200.tar.gz
libiconv-1.14.tar.gz suphp-0.7.2.tar.gz
libmcrypt-2.5.8.tar.gz versions.txt
libpng-1.6.19.tar.gz webalizer-2.23-08-src.tgz
libsrs_alt-1.0.tar.bz2 webapps.logrotate
Any help?
rm -f /usr/local/directadmin/custombuild/.custombuild
I have the same problem, the Update Software tab and Build Software tab both show up empty. This happens when you set the MariaDB version to 10.1 (I noticed you also have it configured). If you switch it back to 10.0 the tabs work again.The other day I changed some options through the interface and hereafter its not showing any updates anymore in the "Update Software" tab and not showing any builds in the "Build Software tab".
Anybody knows what is going wrong?
Fixed in CB 2.0 rev. 1485.
Nice, thanks. But I think you forgot to upload it since I can't find it on files1 yet![]()
Code:cd /usr/local/directadmin/custombuild ./build update
