When I try to use POP3 with SSL, Gmail complains: "Certificate is self-signed"
About cloudflare, "server.hostname.com", must have record in the cloudflare.
Oke so that would mean he would need to add a "server" A record in his primary domain setting.
Mail records are all visible there if I'm not mistaken, or does that work in another way at cloudflare? I don't know what that "proxied" means or does behind the domain name record and the www record.
yes, All records that need access from outside, must add in cloudflare and must be "grey cloud". Behide proxy mail won't work. because even you push your domain behide proxy, they can saw your server IPs from email raw data that you sending to other.
Some important records must be grey cloud, Like "server", "mail", ..etc..
So it useless if only 2 records "www" or "domain.com" behide proxy. Because other records need to be "grey cloud"( bypass proxy ).
It can be only serve as cache, but can't hide or protect yourself from ddos. Because they can saw your real IPs from other records.
if you don't care about this, it should be fine.
Yes but I ment from the screenshot I seen only proxy and DNS Only. So I was wondering if the "dns only" was the grey cloud option you ment, or if there is a specific seperate "grey cloud" option in the pulldown.
Thanks jamgames2 and Zhenyapan! And of course a big thanks again to Richard.
I've taken all of the info from this thread and Richard's guide and compiled into the course of action I'll be taking.
If I've screwed anything up, missed anything, or doing anything in the wrong order, please let me know!
Step 1: Set the hostname via SSH
Via SSH as root:
# hostnamectl set-hostname server.primarydomain.com
- Now check your /etc/hostname file and make sure server.primarydomain.com is there.
If not, adjust it.
- Check your /etc/hosts file and make sure it contains this info:
127.0.0.1 localhost.localdomain localhost
your.ip.ad.res server.primarydomain.com server
Step 2: Reboot your server and then issue these commands to make sure they return the correct hostname.
# hostname
# hostname -f
Both commands should return: server.primarydomain.com
Step 3: Now go into the DA control panel and change the hostname to server.primarydomain.com
Admin -> Server Manager -> Administrator Settings -> Server Settings
Server's Hostname:
change from www.primarydomain.com to server.primarydomain.com
Step 4: Create DNS records on the server for server.primarydomain.com
and the directory for it under /etc/virtual
Admin -> Server Manager -> DNS Administration -> Add DNS Zone
- First check to see if server-xx-xx-xx-xx.da.direct exists.
If it does, delete it.
- Now add the DNS Zone:
domain: server.primarydomain.com <-- no period
ip address: ip.add.re.ss
ns1.primarydomain.com <-- no period
ns2.primarydomain.com <-- no period
- Now go into the DNS Zone: server.primarydomain.com
You should see these records (in addition to the records that are already there. Leave those additional records there)
Name TTL Type Value
server.primarydomain.com. 14400 A ip.add.re.ss
server.primarydomain.com. NS ns1.primarydomain.com. <-- period at end
server.primarydomain.com. NS ns2.primarydomain.com. <-- period at end
- Due to a bug, you need to login via SSH and go to the /etc/virtual directory and
make sure that the directory server.primarydomain.com exists.
^^ I did not encounter this bug, the directory was there.
If not, create it and chown it to mail:mail
And set the permissions to 711
# cd /etc/virtual
# mkdir server.primarydomain.com
# chown mail:mail server.primarydomain.com
Step 5: Create a DKIM record for the hostname and copy the records to Cloudflare
./dkim_create.sh server.primarydomain.com
- If all is correct it will create the same DKIM record as in your primarydomain.com
But you should check to make sure it's correct (in my case it was not, no idea why)
- In the end, between DirectAdmin and CloudFlare you're trying to achieve this:
The only kind of tricky part is copying the 'server.primarydomain.com' key to Cloudflare.
It goes under CloudFlare -> PrimaryDomain.com -> but the 'Name' of the Cloudflare record should be: x._domainkey.server
Step 6: CloudFlare
- Add an A record for server.primarydomain.com
Disable the Proxy (set to 'DNS only')
^^ Wondering if maybe the CloudFlare step should be done earlier, like right after Step 1. Can't hurt anything?
- If you use CloudFlare as external DNS, I would suggest for the primary domain to also copy the SPF and DKIM TXT records.
Step 7: Ask owner of the Server IP Address (Webhost) to add a PTR / Reverse DNS record for IPv4 and IPv6
Please add a PTR / Reverse DNS record for my IPv4 address: A.B.C.D
And point it to: server.primarydomain.com.
And please add one for my IPv6 address as well: y:y:y:y:y:y:x.x.x.x.
Step 8: Once the PTR / Reverse DNS records have been added
Wait about a half hour for the hostname to resolve.
# nslookup [server ip address]
It should resolve to server.primarydomain.com
- Now you can request a new SSL certificate for your hostname.
./letsencrypt.sh request_single server.primarydomain.com 4096
- Once you have a certificate for your hostname, you can turn on ssl=1 in directadmin.conf
Step 9: Now let's see what happens when I run:
# openssl s_client -showcerts -connect ip.ad.dre.ss:995
Woo hoo! Success. No more 'self signed' certificate.
And Gmail now approves of my POP3 mail server over Port 995.
Be sure to use: server.primarydomain.com
And not your IP address.
If I've screwed anything up, missed anything, or in the wrong order, please let me know!
Thank you
127.0.0.1 localhost
should be
127.0.0.1 localhost.localdomain localhost your.ip.ad.res server.primarydomain.com server
(should I CHMOD 600?)
Ah I see I mist that one, all others are normally 711 so do CHMOD 711 to keep everything the same. I will adjust my manual for this. Good find. (y)
I would swap step 3 and 4, but wait the half an hour after creating the hostname via DNS administration.
So that waiting part belongs to the creation of the hostname DNS record.
After the wait and verify, the hostname certificate creation.
Step 6.
And same for you ipv6.
End of story/manual.
Forget all you put below it. Don't use PTR records yourself in DA. It's extra work and does nothing.
Your host should now how to put in the rDNS/PTR records otherwise he's not competent enough. ;)
Looks good!
should be
Step 6.
Looks good!
Thank you, I have modified the steps above.
So everything seemed to go well...
- /etc/hostname contained server,primarydomain.com
- /etc/hosts did *not* automatically contain:
Instead, it contained:
your.ip.ad.res www.primarydomain.com www
(my current hostname)
So I changed that line to:
- hostname and hostname -f both returned the correct response after reboot
- Admin -> Server Manager -> Administrator Settings -> Server Settings
Changed hostname to: server.primarydomain.com
- Admin -> Server Manager -> DNS Administration
-> PrimaryDomain.com (as the admin in admin level)
^^ I assume it was fine to add the new records here, and not as a new DNS Zone
- server-xx-xx-xx-xx.da.direct record did not exist
- added the new DNS records ....
- the bug did not seem to exist for me.
Under /etc/virtual my server.primarydomain.com directory was already created and with the correct permissions and owner
- Cloudflare A record is set. Pinging server.primarydomain.com returns my server IP.
- I waited an hour, and then tried: nslookup [server ip]
But I get: server can't find [reversed ip address].in-addr.arpa.: NXDOMAIN
I have not yet contacted the IP address owner (webhost) to create the PTR / rDNS record.
*Before* I have the PTR / rDNS record created, should the nslookup command work at this point?
Or not until after that step? I would think not until after.
Thank you
I normally write NS records for server in full but I guess it will be fine like that too.
Good to read the bug did not exist for you, it might have been fixed, although it still exist on automatic host creation on a new setup.
You have to contact your host then, because the rDNS/PTR is not setup or not setup correctly yet.
Since you didn't do that yet, this result is logic.
This will only work ater this setup.
And only if this resolves then you should try and create the ssl certificate for your hostname.
Thank you, I was just wondering what you mean by this.
When I click on 'Add Record' to add an NS record, the input box looks like this.
Beside Name I enter: server
Do you mean you would enter something different?
Ah oke, I mostly still work with the enhanced theme so I can punt server.domain.com. in there, that seems not to be required anymore in Evo theme.
So forget my comment about that. It's fine as you did.
Woo hoo, success! After my host updated my PTR record, I continued with the steps:
Once your PTR / Reverse DNS records have been added....
- Wait half an hour
# nslookup ip.ad.dre.ss
# cd /usr/local/directadmin/scripts
# ./letsencrypt.sh request_single server.primarydomain.com 4096
# nano /usr/local/directadmin/conf/directadmin.conf
# systemctl restart directadmin
^^ Note: This was already done for me. I'm assuming during the Let's Encrypt certificate request.
# openssl s_client -showcerts -connect ip.add.re.ss:995
Success! No more 'self signed' certificate.
And Gmail now approves of my POP3 mail server over Port 995 with SSL enabled.
Thanks again Richard!
1. I assume it's normal that when accessing...
https://ip.ad.dr.es:2222
The browser complains the certificate is not valid for the IP address.
Accessing via...
https://server.primarydomain.com:2222
Works fine.
2. In Gmail, I am setting up individual accounts for each of my domains.
For POP, they will all obviously use for mail retrieval: server.primarydomain.com
But Gmail also gives you the capability to 'send as' your domain.
For example, I want to be able to send as:
[email protected]
[email protected]
[email protected]
In Gmail, when it asks for my SMTP server info for domain1.com
I used:
smtp.domain1.com port: 587 over TLS
And this does work. No complaints from Gmail.
But I'm wondering two things:
a) When I run:
# openssl s_client -showcerts -connect smtp.domain1.com:587
It says:
no peer certificate available
No client certificate CA names sent
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1703018951
Timeout : 300 (sec)
Verify return code: 0 (ok)
Is this normal? Prior to this, I had made sure that:
smtp.domain1.com was not proxied on Cloudflare (resolves to my IP)
and...
I retrieved LE certificates using the DA interface, including for smtp.domain1.com
b) Is it 'best' to set things up like this:
smtp.domain1.com
smtp.domain2.com
smtp.domain3.com
I just wanted to make sure I wasn't supposed to be using server.primarydomain.com for all domains or something like that.
Thank you
Yes that is correct. SSL certificates are seldom issues for ip addresses mostly for domain names and FQDN hostnames and such.
If you really also want to be able to access it via IP this way, dan you have to turn the SSL=1 back to 0 in the directadmin.conf file. However, why should you do it as you can use https://server.primarydomain.com:222 and even any https://somedomain.com:2222 on the server, to be able to login as admin.
Why obviously? DA uses by default mail.comain.com for receiving and smtp (or mail).domain.com for sending mail so for mail retrieval you should also be able to use mail.domain.com if all is correct.
However, it is also possible to use the hostname for mail, there are more hosters which do it that way.
Yes that is normal I guess. I'm seeing the same when testing on a domain on my server. But they do use SSL/TLS/STARTTLS.
Maybe yes, you can always change later if needed. I always advise people to setup things so everything is at least working by default, and make customisations or changes afterwards. This way it's easier to detect when/where it can have gone wrong (if it would go wrong).
Just to be sure we are still differentiating between primarydomain.com and domain1.com, domain2.com, etc.
hostname = server.primarydomain.com
For me, if I try the following:
POP3
mail.domain1.com
^^ Gmail complains: "Server returned error: "SSL error: ok Hostname "mail.domain1.com" doesn't match any SANs: "server.primarydomain.com"
^^ To note: I have no issues *sending* mail from mail.domain1.com through Gmail.
mail.primarydomain.com
^^ Gmail complains: "Server returned error: "SSL error: ok Hostname "mail.primarydomain.com" doesn't match any SANs: "server.primarydomain.com""
^^ Gmail is happy.
Here's what I'm currently going with in CloudFlare...
A) My understanding is that if you have an MX record of mail.domain1.com
You should also have an 'A' record that looks like the above.
If you don't remove the CloudFlare proxy for this record, the lookup for the mail server returns something like:
dc-randomstringofletters.domain1.com
After removing the proxy, the lookup for the mail server returns what is expected:
mail.domain1.com
No idea if this matters.
What I'm currently going with in Gmail...
I've tested this setup for Domain1.com with 4 testing sites (MX Toolbox, Zonemaster, LeafDNS, IntoDNS)
As well as my DKIM/DMARC/SPF settings with MX Toolbox and Mail-Tester.
I'm not getting any reports of anything being wrong, so I feel somewhat confident in going with these settings for my 10 other domains.
Unless there's something I could be doing better!
I don't use Cloudflare, but I thought things like mail should not be proxied. I can be mistaken.
So as long as you use mail and not smtp I guess things are fine.
The complaint about SAN is not an issue as long as it's only a complaint and not an error and not refusing mail or something. But that is probably because you are retrieving mail from the hostname instead of from the domain name.
Does it also give this error if you use mail.domain1.com for retrieval? Otherwise you can better use mail.domain1.com to retrieve mail.
If you get a 10/10 on mail-tester.com and Gmail is working fine too, you should be fine.
Sorry, yes, when I say 'complain', I mean that Gmail is refusing to proceed when setting up the account (at least in the browser client).
Retrieval / POP 3 / Port 995
mail.domain1.com
^^^ SSL error: ok Hostname "mail.domain1.com" doesn't match any SANs: "server.primarydomain.com""
^^^ Unable to establish secure SSL connection to mail.primarydomain.com
server.primarydomain.com Works
Sending / Port 587
mail.domain1.com Works
It looks like this person from 5 years ago had the same issue:
Googling around, my best guess is something to do with a certificate name not matching.
Yes he's still around. ;)
I don't know, Gmail does odd sometimes. I presume you have a correct SSL certificate for your hostname.
Go to https://crt.sh and check for both your hostname and domain name.
Check that mail_sni=1 is present in your directadmin.conf file.
If that is all correct and you also get a 10/10 on mail-tester.com then as far as I'm concerned you're fine and it's a gMail issue.
Unless @IT_Architect was able to find a solution later on.
At https://crt.sh when I try: server.primarydomain.com (my hostname) it says there were no certificates found.
I was under the impression that I had created a certificate for my hostname based on the steps that I undertook previously...
I remember doing this step, and it seemed to work.
And I don't think I would be able to turn on SSL=1 without it working?
In DirectAdmin -> User -> PrimaryDomain.com -> SSL Certificates
I do not have an entry for: server.primarydomain.com
Am I supposed to also create the subdomain: server.primarydomain.com
And then add it to the list of certificates to retrieve?
If I go to: https://www.ssllabs.com/ssltest//index.html
And try the certificate test for: server.primarydomain.com
It claims I do have a certificate and everything looks fine.
And also...
says...
server.primarydomain.com resolves to IP Address
Server Type: Apache/2
The certificate should be trusted by all major web browsers (all the correct intermediate certificates are installed).
The certificate will expire in 87 days.
The hostname (server.primarydomain.com) is correctly listed in the certificate.
Not sure why https://crt.sh can't see it.
I can confirm that mail_sni=1
