- Aug 30, 2021
MariaDB will not stop working after two years. You can continue running it for as long as you need.And whats about the MariaDB 10.6 EOL in ~2 years?
If you do not consider running MariaDB 10.6 after two years as an option - then yes, I think you could consider it worthless for you.Exactly, making our licenses worthless because a decent hoster does not use EOL stuff.
Maybe slightly longer but yes. And you know what I mean, don't start giving smart answers. This is totally different as what DA manement told us before. And if idiots want to use old stuff, it's on them. Doens't mean it's good practice.If you do not consider running MariaDB 10.6 after two years as an option - then yes, I think you could consider it worthless for you.
Hi everyone.
Thanks for the feedback. Let us clarify the situation of legacy licenses. The future of legacy licenses is somewhat stagnant due to a shift towards ongoing maintenance rather than future features/integrations.
Why you hinder us on purpose, to install higher MariaDB versions at our own risk? That is was nobody understands. Simply remove the license not valid blocking for higher MariaDB versions, and a lot of us will be happy again. Whats the problem with this?If you do not consider running MariaDB 10.6 after two years as an option - then yes, I think you could consider it worthless for you.
We do allow you to not use CustomBuild. The fact that CustomBuild was merged with DirectAdmin does not mean you must use it now. You can continue to manually install all software components. As long as DirectAdmin is compatible with the external software it will work just fine.Why are you not letting users install opensource software outside of custombuild?
Legacy DirectAdmin will not work with higher MariaDB versions even if they are installed manually or DB is in external server.Why you hinder us on purpose, to install higher MariaDB versions at our own risk?
I have Personal license since November 2019 and now I see I need to bought more expensive license Personal Plus to have updated MariaDB. I don't need any Pro Pack features. Why you don't release some lite version of license? Personal Plus is over twice expensive as old Personal license (60$ vs 24$ per year!). I'm freelancer and I have VPS with DirectAdmin only for two hobby projects - 1 account and 10 domains limit is enough for me. Personal license was a really license for small projects. Now you make me have to look for another alternative to DA. What's worse, last month I paid for the license for another year - I saw this thread only a week after paying. Thanks forWhile we appreciate all the feedback given, much of it pertains to extreme conversion discounts (for example, some suggesting full Standard licenses priced lower than our Personal PLUS license), under the assumption that enough extreme-discounted license orders will provide sufficient resources. Unfortunately this is not sustainable, and is an echo of our failed (and now retired) extreme-discount internal pricing model.
But why? I get that "they" will not receive MariaDB updates from you guys, sure most of them can live with that.Legacy DirectAdmin will not work with higher MariaDB versions even if they are installed manually or DB is in external server.
Before the check was introduced many people had higher MariaDB versions working just fine and was working as expectedLegacy DirectAdmin will not work with higher MariaDB versions even if they are installed manually or DB is in external server.
We do not provide MariaDB updates. MariaDB developers does that.But why? I get that "they" will not receive MariaDB updates from you guys, sure most of them can live with that.
But why taking away the ability to do it them selfs? Most owners of these licenses are probably good enough with Linux to install / implement it them selfs (or google) but got spoiled with CustomBuild.
This is inaccurate. We know how many systems were affected and it was only a handful. The ones who reached out about this were offered a free MariaDB downgrade by our tech staff. Most did not care because they they were just testing things out.Before the check was introduced many people had higher MariaDB versions working just fine and was working as expected
So my statement is in fact accurate then and your reply is a contradiction in itself.This is inaccurate. We know how many systems were affected and it was only a handful. The ones who reached out about this were offered a free MariaDB downgrade by our tech staff. Most did not care because they they were just testing things out.
This isnt making easy for us but for the last time:
If we buy as existing customer NOW, then the lifetime license we buy will be lifetime and get all the program updates till 2038 ?
When confirmed we will buy one![]()
Existing customer with a license already in your account, then yes! (A completely empty account, NO)
