2026-09-17T11:44:13.562399396+02:00 ERROR Error error="renew certificate: could not obtain the certificate for \"beefyvm.com\": resolver: one or more domains had a problem: [pop.beefyvm.com: invalid authorization: acme: error: 400 :: urn:ietfarams:acme:error:dns :: DNS problem: NXDOMAIN looking up A for pop.beefyvm.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for pop.beefyvm.com - check that a DNS record exists for this domain] [smtp.beefyvm.com: invalid authorization: acme: error: 400 :: urn:ietf
arams:acme:error:dns :: DNS problem: NXDOMAIN looking up A for smtp.beefyvm.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for smtp.beefyvm.com - check that a DNS record exists for this domain]"
/var/www/html/.well-known/{rand-name} file and the make a request to curl http://sub.example.com/.well-known/acme-challenge/{rand-name}. In other words it does the same HTTP challenge test that ACME would perform but everything is executed locally (inside the server)./etc/hosts.nameserver 127.0.0.1 in the /etc/resolv.conf) and using external nameservers for this domain.root@vps:~# curl http://beefyvm.com/.well-known/acme-challenge/foobar
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
<snip>
</body></html>
root@vps:~# curl http://pop.beefyvm.com/.well-known/acme-challenge/foobar
<html><head>
<snip>
</body></html>
root@vps:~# dig A pop.beefyvm.com @localhost
; <<>> DiG 9.18.49-1~deb12u2-Debian <<>> A pop.beefyvm.com @localhost
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 45962
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
; COOKIE: 7fb32a290a0b247f010000006ab40f2b87e54aaf9bdde89a (good)
;; QUESTION SECTION:
;pop.beefyvm.com. IN A
;; AUTHORITY SECTION:
beefyvm.com. 1800 IN SOA ns1.xxxxxx. hostmaster.beefyvm.com. 2026091700 3600 3600 1209600 1800
;; Query time: 0 msec
;; SERVER: ::1#53(localhost) (UDP)
;; WHEN: Wed Sep 23 19:40:59 CEST 2026
;; MSG SIZE rcvd: 140
root@vps:~# cat /etc/resolv.conf
nameserver ip.v4.number.1
nameserver ip.v4.number.2
nameserver ip.v6.number.3
nameserver ip.v6.number.4
root@vps:~# dig A pop.beefyvm.com @ip.v4.number.1
; <<>> DiG 9.18.49-1~deb12u2-Debian <<>> A pop.beefyvm.com @ip.v4.number.1
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 39176
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
; EDNS: version: 0, flags:; udp: 512
; EDE: 29: (Result from negative cache for entire name)
beefyvm.com. 1224 IN SOA ns1.xxx. hostmaster.beefyvm.com. 2026091700 3600 3600 1209600 1800
;; SERVER: ip.v4.number.1#53(ip.v4.number.1) (UDP)
;; WHEN: Wed Sep 23 19:45:17 CEST 2026
;; MSG SIZE rcvd: 160
root@vps:~# dig A pop.beefyvm.com @ip.v4.number.2
; <<>> DiG 9.18.49-1~deb12u2-Debian <<>> A pop.beefyvm.com @ip.v4.number.2
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 9346
beefyvm.com. 1800 IN SOA ns1.xxx. hostmaster.beefyvm.com. 2026091700 3600 3600 1209600 1800
;; Query time: 132 msec
;; SERVER: ip.v4.number.2#53(ip.v4.number.2) (UDP)
;; WHEN: Wed Sep 23 19:45:23 CEST 2026
;; MSG SIZE rcvd: 112
root@vps:~# dig A pop.beefyvm.com @ip.v6.number.3
; <<>> DiG 9.18.49-1~deb12u2-Debian <<>> A pop.beefyvm.com @ip.v6.number.3
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 47547
beefyvm.com. 1212 IN SOA ns1.xxx.nl. hostmaster.beefyvm.com. 2026091700 3600 3600 1209600 1800
;; SERVER: ip.v6.number.3#53(ip.v6.number.3) (UDP)
;; WHEN: Wed Sep 23 19:45:29 CEST 2026
root@vps:~# dig A pop.beefyvm.com @ip.v6.number.4
; <<>> DiG 9.18.49-1~deb12u2-Debian <<>> A pop.beefyvm.com @ip.v6.number.4
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 45511
beefyvm.com. 1787 IN SOA ns1.xxx. hostmaster.beefyvm.com. 2026091700 3600 3600 1209600 1800
;; Query time: 4 msec
;; SERVER: ip.v6.number.4#53(ip.v6.number.4) (UDP)
;; WHEN: Wed Sep 23 19:45:36 CEST 2026
root@vps:~# getent hosts pop.beefyvm.com
1234:1234:1234:1234::1 pop.beefyvm.com.xxx.nl
root@vps:~# getent hosts this-should-not-even-exist
2a04:52c0:101:9ce::1 this-should-not-even-exist.xxx.nl
LOCALDOMAIN=. curl [...]
search clause in resolv.conf that points to a domain with wildcard CNAME record.curl, but it uses default system resolver for name resolution, so it is affected by global system resolver configuration.How to debug and investigate the issue?
