Incoming mail problem and LAN connection problem
Well that is very odd. Because then with a dig -t NS on your domainname, then I should always get the NS records, even if your nameservers are not working or are offline.
And this is not the case at the moment.
I would suggest to contact your domain name registrar and have them kick the nameservers again.
It is very strange. I will try. Thanks for your advice
The domain is registered, but nameservers are not accessible: https://www.dnsinspect.com/metiselektrik.com/10846119 https://www.dnsinspect.com/elektrikakademi.com/10846120
Starting Nmap 7.92 ( https://nmap.org ) at 2025-06-25 01:46 +07
Nmap scan report for elektrik***demi.com (95.70.***.170)
Host is up (0.047s latency).
Not shown: 987 filtered tcp ports (no-response)
PORT     STATE SERVICE
21/tcp   open  ftp
22/tcp   open  ssh
25/tcp   open  smtp
80/tcp   open  http
110/tcp  open  pop3
143/tcp  open  imap
443/tcp  open  https
465/tcp  open  smtps
587/tcp  open  submission
993/tcp  open  imaps
995/tcp  open  pop3s
2222/tcp open  EtherNetIP-1
5000/tcp open  upnp
Nmap done: 1 IP address (1 host up) scanned in 5.05 seconds
Starting Nmap 7.92 ( https://nmap.org ) at 2025-06-25 01:50 +07
Nmap scan report for elektrik***demi.com (95.70.147.170)
Host is up (0.048s latency).
Not shown: 996 open|filtered udp ports (no-response)
PORT     STATE  SERVICE
21/udp   closed ftp
80/udp   closed http
443/udp  closed https
5000/udp closed upnp
Nmap done: 1 IP address (1 host up) scanned in 24.24 seconds
PORT     STATE SERVICE
21/tcp   open  ftp
22/tcp   open  ssh
25/tcp   open  smtp
80/tcp   open  http
110/tcp  open  pop3
143/tcp  open  imap
443/tcp  open  https
465/tcp  open  smtps
993/tcp  open  imaps
995/tcp  open  pop3s
5000/tcp open  upnp
PORT     STATE  SERVICE
21/udp   closed ftp
80/udp   closed http
I think I still need to change something on server conf files
