[PLUGIN] EN-ClamAV - ClamAV Interface for DirectAdmin
Maybe because I have Ubuntu?
The Standard plan is the modern license including everything.
If you don't see it, then it's not OS dependend. Unfortunately I don't have a modern license, so I can't check for you.
Maybe @ericosman can tell you where to find it or why you don't need it, as he's the one who said that.
When you select a user, and edit it
Admin --> Show all users --> click on the user --> user --> Modify
There you will see ClamAV (check the box)
After that login as the user and you will see clamav
