Adding Mailman Virtual Hosts
Adding Mailman Virtual Hosts  version 0.9
(c)07-22-08 Thom LaCosta
A Mailman installation can provide mailing list service for all domains on
  a server.  At this time, the system administrator must perform certain
  functions.  Once these functions are accomplished, either the Systems
  Administrator or the Site Administrator can finish the installation.
Mailman can be installed via the steps posted at
http://directadmin.com/forum/showthread.php?t=25596&highlight=mailman
A. Add mailman virtual host
   At this time, only the system administrator can perform this function
   Log in via SSH as admin or root
   cd /usr/local/mailman/Mailman
   Edit the file mm_cfg.py
   At the end of the file, add the virtual host after these lines
   # Put YOUR site-specific settings below this line.
   add_virtualhost( 'mailman.the_domain.you_add' )
   restart mailman
   service mailman restart
B. Add DNS Entry
   This step must be performed by the System Administrator unless the Site
   Administrator had been    given access to DNS Management.  Add two
   entries via DNS Management as follows:
www.mailman	A	the_ip_that_the_domain_uses
C. Add virtual Host Container to /etc/httpd/conf/httpd.conf
   Sample
   <VirtualHost 12.180.200.76:80>
        ServerName
www.mailman.virtual_domain
        ServerAlias
www.mailman.virtual_domain virtual.domain
        ServerAdmin
[email protected]
        DocumentRoot /usr/local/mailman
        ScriptAlias /mailman/ /usr/local/mailman/cgi-bin/
        UseCanonicalName OFF
        User mailman
        Group mailman
        CustomLog /var/log/httpd/domains/mailman.virtual_domain.bytes bytes
        CustomLog /var/log/httpd/domains/mailman.virtual_domain.log combined
        ErrorLog /var/log/httpd/domains/mailman.virtual_domain.error.log
   <Directory /usr/local/mailman/cgi-bin/>
       AllowOverride All
       Options ExecCGI
       Order allow,deny
       Allow from all
   </Directory>
   Alias /pipermail/ /usr/local/mailman/archives/public/
   <Directory /usr/local/mailman/archives/public>
       Options Indexes MultiViews FollowSymLinks
       AllowOverride All
       Order allow,deny
       Allow from all
   </Directory>
   </VirtualHost>
Restart Apache
service httpd restart
D. Add aliases
   Each new Mailman list requires aliases to be entered in /etc/aliases
   Mailman will send a message to the list owner with the aliases to add
   There are two ways to add the aliases for Mailman.  One is to add them
   via the control panel as forwarders.  The other method is to simply add
   the aliases via an ssh session and restart Exim when finished
   service exim restart
   Sample Alias File for list named new-list
new-list:             "|/usr/local/mailman/mail/mailman post new-list"
new-list-admin:       "|/usr/local/mailman/mail/mailman admin new-list"
new-list-bounces:     "|/usr/local/mailman/mail/mailman bounces new-list"
new-list-confirm:     "|/usr/local/mailman/mail/mailman confirm new-list"
new-list-join:        "|/usr/local/mailman/mail/mailman join new-list"
new-list-leave:       "|/usr/local/mailman/mail/mailman leave new-list"
new-list-owner:       "|/usr/local/mailman/mail/mailman owner new-list"
new-list-request:     "|/usr/local/mailman/mail/mailman request new-list"
new-list-subscribe:   "|/usr/local/mailman/mail/mailman subscribe new-list"
new-list-unsubscribe: "|/usr/local/mailman/mail/mailman unsubscribe new-list"
E. Creating List
   The new list can be created via the web once the virtual host information
   propagates.
   One would browse to
www.mailman.the_ip_that_the_domain_uses/mailman/admin
   select create a list and at
www.mailman.the_ip_that_the_domain_uses/mailman/create
   create the list new-list, use the email of the list owner and select send
   notification to list owner
   The list may be created prior to propagation via ssh.  If you're logged in
   as root and create the lists,
   cd /usr/local/mailman/lists/name_of_the_new_list and change ownership
   and group of the files to mailman
   chown mailman:mailman
   Another method would be to su to mailman ( su mailman ), change to the
   mailman directory cd /usr/local/mailman and issue the command bin/newlist
