jkirker
- Nov 22, 2012
Would "admin" still be available in /etc/passwd?
I'm not sure - will it be if I change the admin username as follows?
/usr/local/direcatadmin/scripts/change_username.sh admin lkajsdf93
Would there be more users that think that "Update software" should be the index page (main tab)?I like the idea.
/usr/local/directadmin/custombuild/custom/roundcube/plugins/
/usr/local/directadmin/custombuild/custom/roundcube/skins/
/usr/local/directadmin/custombuild/custom/roundcube/config.inc.php
/usr/local/directadmin/custombuild/custom/roundcube/.htaccess
That would break CustomBuild plugin. I will think about the solution for it, and I think that diradmin user could be used by default then in this case.
shoot I missed this but its not an issue now, thats though I do appreciate that.Please contact me using PM with your OS and arch (32/64bit) and I'll provide the link for you![]()
and I new it was php issue so have recompiled php and apache, apache starts but getting connection reset error on sites.Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe.
I upgraded and all seem fine
(do miss the on/off selection buttons )![]()
grr accidentally set php to mod_php while enabling event mpm and cannot set sites back up and running.
got the warning
Please set MPM mode to auto, then reinstall Apache or just do the rewrite of configuration files after the change. You shouldn't run mod_php with event MPM![]()
