Important: Upgrade your DirectAdmin to ensure compatibility with our new licensing system
If possible, could the old licensing infrastructure allow selected fixed client IP(s) for those legacy CL4, CL5 DA to access?
We also have few legacy on CL4 (PHP 4.4 + MySQL 4.0), CL5.
Due to MySQL 4.0 character set issue (latin1, Unicode, non-English characters), so keep there.
Probably it will fail to start DirectAdmin service, cannot access port 2222.
(i.e. Web, SMTP, POP/IMAP, database, DNS shall continue to run, but you cannot manage/adjust them via DirectAdmin panel)
I have a server for old code. php 5.3 and mysql 5.5. I don't know if I update, will it affect anything
I think these are available in custombuild 2.0 regardless of the OS/DA version, so you can do them on CentOS 7 or even CentOS6 an continue the usage of DA.
I would wait on an answer from DA for that. I don't think php 5.3 is still available and probably mysql 5.5 neither anymore in custombuild 2.0.
Just seen a post of somebody wanting to use MariaDB 10.2 and that wasn't possible either.
However I'm also not 100% sure.
Yes I’m having the same issue. I have some old sites running on a old server with php 5.3. Already tried to get older php version running on a new server but doesn’t seem easy to do
I was able to run CentOS 6 with PHP 5.2.17 and MySQL 5.1
Compiled onLinux 64-bit
Compile DateDec 31 2021, 11:58:02
Server Version1.63.4
Current Available Version1.63.4
I know its not an ideal OS to continue to run on, but at least its giving my customers a little more time to prepare for the migration.
Like this,. I'm sure it can be done with later PHP versions.
Were you able to update DA on CentOS 6 by changing the licence from CentOS 6 to Linux 64-bit? Could this not have unforseen consequences as recent versions of DA don't support CentOS 6 anymore?
I hope this is still supported for more time.
It says CentOS6.
I don't need to update the DA itself,. just keep it active as it is will be fine until we retire these servers.
It says CentOS6.
Seems like you are right, I was able to update a Debian 8 server to the latest DA version by changing the license from Debian 8 to this one.
Also got some CentOS 5 boxes with old MySQL/PHP versions needed for scripts, some security tweaks like modsecurity, csf etc and they are working perfectly fine.
I would be very grateful if there will be a way to keep Directadmin running on them...
@wtptrs @SupermanInNY Yes, versions like CentOS 6 and Debian 8 have become EOL under our policy, but only recently. So there is DA binaries modern enough to support the new licensing system. :)
@pat0 Feel free to open a ticket. There's some people who say they've invested major resources into a specific configuration, and they simply cannot upgrade. We might be able to offer a solution.
I got this to work on one server (change license from Debian 8 to Linux 64-bit glibc 2.12+, manually update DA, run updateLicense.sh script) where the 'compiled on' license now says 'Linux 64-bit' and everything works fine.
On another Debian 8 server I tried this on the 'compiled on' license keeps saying 'CentOS 6' and I'm unable to start Directadmin due to a license error. Overriding my OS to Debian 8 and updating reverts Directadmin back to version 1.62 which is too old for the new licensing system. Is there any way to force the 'compiled on' license to 'Linux 64-bit'?
I also have some old Debian 8 servers with DA which are actually just online still while some clients sort out their last migrations. I would hate to be forced to dist-upgrade these, or hack around like discussed above to get a newer version than 1.62.x. Yet I am forced to do something as they won't be able to complete the last migrations without control panel.
Out of the box suggestion: why not allow us to consciously switch to an unportioned licenses for EOL operating systems? It would solve everyone's problem, and if the server is dist-upgraded after all it would automatically revert to portioned licenses anyway.
update: it was actually trivial to update all to 1.63.5 using the Linux 64-bit version so my problem is solved. Still think the above is a good idea :)
I have a Debian 8 Custombuild 2.0 server with DirectAdmin 1.62.0 running.
In the DA GUI under Licensing/Updates it says Current Available Version 1.634000
I've tried to Update DirectAdmin but I get the message:
'This OS is now End-Of-Life and no further updates are availble. The automated updater will no longer accept request after Wed Sep 8 2021 (manual attempts can be done with https://help.directadmin.com/item.php?id=29) but may not do anything.'
I was busy to migrate to a new server, but due to some issues not ready yet.
Any suggestion is welcome! Thanks.
Will the solution Omines used works for me as well? (update: it was actually trivial to update all to 1.63.5 using the Linux 64-bit version so my problem is solved.)
Could you please list the steps you performed to do this? I'm having issues trying this on some servers.
Could you please list the steps you performed to get this to work?
