Which method did you try there? I'd suggest trying https://docs.directadmin.com/direct...ting-da.html#manual-update-using-cli-commandsI have Ubuntu 18.04 (which should be Debian 9 based)
Unfortunately the upgrade doesn't work, which means you guys stopped supporting Ubuntu at all?
Or if I upgrade my OS to Ubuntu 20.04, the DirectAmdin upgrade should work again?
Thanks, the manual update did the job, now I have 1.63.4 and auto-update from the interface also worksWhich method did you try there? I'd suggest trying https://docs.directadmin.com/direct...ting-da.html#manual-update-using-cli-commands
Probably it will fail to start DirectAdmin service, cannot access port 2222.If we don't upgrade, my server will be shutdown?
I have a server for old code. php 5.3 and mysql 5.5. I don't know if I update, will it affect anythingProbably it will fail to start DirectAdmin service, cannot access port 2222.
(i.e. Web, SMTP, POP/IMAP, database, DNS shall continue to run, but you cannot manage/adjust them via DirectAdmin panel)
I think these are available in custombuild 2.0 regardless of the OS/DA version, so you can do them on CentOS 7 or even CentOS6 an continue the usage of DA.I have a server for old code. php 5.3 and mysql 5.5. I don't know if I update, will it affect anything
Yes I’m having the same issue. I have some old sites running on a old server with php 5.3. Already tried to get older php version running on a new server but doesn’t seem easy to doI would wait on an answer from DA for that. I don't think php 5.3 is still available and probably mysql 5.5 neither anymore in custombuild 2.0.
Just seen a post of somebody wanting to use MariaDB 10.2 and that wasn't possible either.
However I'm also not 100% sure.
I was able to run CentOS 6 with PHP 5.2.17 and MySQL 5.1Yes I’m having the same issue. I have some old sites running on a old server with php 5.3. Already tried to get older php version running on a new server but doesn’t seem easy to do
| Compiled on | Linux 64-bit |
| Compile Date | Dec 31 2021, 11:58:02 |
| Server Version | 1.63.4 |
| Current Available Version | 1.63.4 |
Seems like you are right, I was able to update a Debian 8 server to the latest DA version by changing the license from Debian 8 to this one.View attachment 5144
I hope this is still supported for more time.
It says CentOS6.
I don't need to update the DA itself,. just keep it active as it is will be fine until we retire these servers.
@wtptrs @SupermanInNY Yes, versions like CentOS 6 and Debian 8 have become EOL under our policy, but only recently. So there is DA binaries modern enough to support the new licensing system.
@pat0 Feel free to open a ticket. There's some people who say they've invested major resources into a specific configuration, and they simply cannot upgrade. We might be able to offer a solution.
I have a Debian 8 Custombuild 2.0 server with DirectAdmin 1.62.0 running.
In the DA GUI under Licensing/Updates it says Current Available Version 1.634000
I've tried to Update DirectAdmin but I get the message:
'This OS is now End-Of-Life and no further updates are availble. The automated updater will no longer accept request after Wed Sep 8 2021 (manual attempts can be done with https://help.directadmin.com/item.php?id=29) but may not do anything.'
I was busy to migrate to a new server, but due to some issues not ready yet.
Any suggestion is welcome! Thanks.
Will the solution Omines used works for me as well? (update: it was actually trivial to update all to 1.63.5 using the Linux 64-bit version so my problem is solved.)
