Hey all,
Did anyone manage to get that file: http://83.98.148.16/imap_da.cpanel.import.pl
If so if you email it me I can host it for a while. I need it as well to get some accounts to DA
Ry
I want this script too. Anyone? please.
Hey all,
Ry
Thank you for the offer, however I think I've found the Maildir data in my backup. It should be inside the directory /homedir/mail/DOMAIN/USER/. I'll see what I can do with that soon.l0rdphi, I don't use your tool, but I can help you. You just need a cPanel server with Maildir I guess or a user backup. Contact me on MSN, ICQ or Skype and I'll give you details.
Phil.
I should be able to get this working without the VPS. Thank you for the offer though.You have about 50 DA Admins waiting eagerly).
I can set up a test cPanel VPS (they give 15 trial licenses) for you to run tests on it if that helps in any way (My cPanel license expired in Feb, - wasn't in use for 4 months as I converted to DA and had to manually move the Maildir-Courier files from the old box to the new box).
Let me know if you want me to set up the VPS.
-Alon.
if cpanel uses mbox, then you'd have to convert to dovecot instead of vm-pop3d.
Once converted, the place the Maildir files into:
/home/username/imap/domain.com/username/Maildir
for dovecot:
http://www.directadmin.com/features.php?id=590
I have a newly installed server, if you want PM me and im sure we can work something out.
