Ah, I didn't realize DA was using Maildir now. cPanel uses Maildir too, so it is just a matter of moving the cPanel files to the right folder.
My DA server is still using mbox and locate doesn't return anything for Maildir. So to implement support in this tool, we'll need to know where exactly the Maildir data should be put in a DA user backup. After I know that, adding support should be easy. I think anyone with a copy of DA using Maildir can answer that--or I could upgrade my server later today and find out.
Cheers, Phil.
getUP, yes, it's very easy to transfer them.
Dovecot is not installed by default.
DirectAdmin said the files should be copied into /home/username/imap/domain.com/username/Maildir. Easy enough?
So without root access to a cpanel server, how do i know which software its running?
/home/USERNAME/imap/DOMAIN.NAME/mailname/Maildir/DIR-STRUCTURE
/home/USERNAME/Maildir/DIR-STRUCTURE
Nor do you give us enough information to help you get it to work.FYI - i couldnt get the emails to work...
9beta1 worked like a charm with Maildir!
