Hi,I get "Extracting cPanel backup..mv: cannot move `/root/import/user' to a subdirectory of itself, `/root/import/user/user'" with every backup now It's a minor bug, but needs to be fixed.
I've been unable to reproduce this with backups from a cPanel 11.1 server.i'm getting the same thing. how can i get around this issue?
Should sent mail be transferred from cpanel to directadmin also?
I did a transfer but the sent mail did not get thru.
Is there a config I should look into?
should i just try repeating the process?
Some questions:
1/ What is the full filename of the cPanel backup file? (e.g., cpmove-user1.tar.gz)
2/ Was the above backup file generated by /scripts/pkgacct or the 'Full Backup' GUI tool?
Additionally, if you don't mind, sending me a "skeletal dump" of your cPanel backup may help:
tar tzf CPANELBACKUP.TAR.GZ | mail [email protected] -s 'CP backup skeletal dump'
Thanks, Phil
Install dovecot on DirectAdmin server.
Hi,1/ I think the backup is called cpmove-apcom.tar.gz (apcom is username) when first created. I renamed to apcom.tar.gz
2/ I used /scripts/pkgacct
I sent the dump with subject "CP backup skeletal dump from mpat89" - you may have got from monil too, ignore that one.
Your help is much appreciated! I'm eager to move cpanel users over to this lovely new panel
