walo
- Mar 19, 2005
Do you mean with a custom htaccess?You will need to do it with Apache!
I think that DirectAdmin doesn't use apache.
I can't think in a way to use another php.ini
Please try again.
Or maybe fopen_wrappers are off in your PHP!
Enable it and after installation you may disable it.
When exactly are you getting this error ?
hey,
im getting this error as soon as i call the script to install.. at the wget command
Softaculous use php, by default php.ini, apache (or cgi requests) use same file and i need add ionCube to php.ini. I mean how to say softaculouse to use another php.ini file (with ionCube) and let apache or default php request load php.ini without ioncube
Hi guys,
I'd like to know if Softaculous is production ready, and how stable it is. If anyone is using it currently on a shared hosting server,. etc..
Thanks![]()
humm thats the reason for the post.
I ran the install using this guide http://www.softaculous.com/docs/install_direct_admin
It didn't make the directory during install and displayed error can't chmod /var/softaculous file or directory not found. Same with chown
Everything installed fine and I added the dir myself and updates the programs.
Running Centos 5.2 32 bit
As I said the directory was not made during install.
some problem:
Code:[root@server ~]# /usr/local/bin/php /usr/local/directadmin/plugins/install_softaculous.php Could not save thnano install_softaculous.php
Is the mkdir function enabled in your PHP CLI ?
Regards,
Alons
The following software were updated during Automatic Cron Updates:
Gallery 2.3.1 - Failed
MyBB 1.4.11 - Failed
Piwigo 2.0.7 - Failed
TikiWiki 4.0 - Failed
OpenX 2.8.2 - Failed
phpList 2.10.10 - Failed
SMF 1.1.11 - Failed
Moodle 1.9.7+ - Failed
Xoops 2.4.2 - Failed
FluxBB 1.2.22 - Failed
CubeCart 3.0.20 - Failed
phpMyFAQ 2.5.5 - Failed
iQDesk 1.0 - Failed
The logs of the Updates are as follows:
Zikula
Current Version is Latest Version......Continuing
AEF
Noahs Classifieds
MediaWiki
WordPress
Coppermine
WebCalendar
TinyWebGallery
DokuWiki
dotProject
b2evolution
LifeType
Dotclear
Textpattern
Joomla
Geeklog
Drupal
Mambo
PHP-Nuke
Nucleus
phpBB
XMB
Gallery
Software not found.....Needs Update
Deleting previous files......
Fetching Latest File......Saved the Latest File Unzipping the files......Error unzipping......Continuing
LinPHA
MyBB
Fetching Latest File......Could not SAVE latest file......Continuing
Phorum
PunBB
Piwigo
Pixelpost
ZenPhoto
PhpWiki
PmWiki
TikiWiki
OpenX
Kamads
PHPads
phpicalendar
phpScheduleIt
phpCollab
PHProjekt
NetOffice
ProjectPier
Serendipity
phpList
Versions dont match.....Needs Update
Webinsta Maillist
poMMo
SquirrelMail
ccMail
LimeSurvey
phpESP
EasyPoll
LittlePoll
Simple PHP Poll
Zen Cart
Freeway
osCommerce
OpenCart
PrestaShop
Advanced Guestbook
SMF
CJ Dynamic Poll
phpShop
phpBook
BellaBook
VX Guestbook
Lazarus
RicarGBooK
Crafty Syntax
Help Center Live
HESK
osTicket
ExoPHPDesk
phpSupport
Open Web Messenger
phpOnline
Aardvark Topsites
Open Blog
Website Baker
sNews
UseBB
Magento
FAQMasterFlex
phpLD
Pligg
Open-Realty
Moodle
WeBid
kPlaylist
Podcast Generator
Impleo
Shadows Rising
Word Search Puzzle
Multiplayer Checkers
MODx
eggBlog
phpAlbum
Shutter
Claroline
PHPfileNavigator
BlackNova Traders
Mantis Bug Tracker
Advanced Poll
SugarCRM
Elgg
Pixie
CodeIgniter
WHMCS
WordPress MU
Xoops
FluxBB
CubeCart
phpMyFAQ
iQDesk
4images
From Softaculous Cron Jobs
