- Feb 27, 2003
DirectAdmin is now powered by a more efficient, more secure, and more feature-rich licensing system.
Instead of relying on the traditional Client ID / License ID / IP address combination, we now offer a secure license key that is used to install DirectAdmin freely wherever you go. There's no more need to login to your account and wait for IP change approvals. Need to install DA on a new server? No problem! Use your key for the new installation, and watch DirectAdmin automatically deactivate on the old server.
Datacenter partners can now create keys that are multi-server, subnet specific / datacenter specific, etc. -- whatever meets their individual requirements. If you are a datacenter, please see this guide instead: https://forum.directadmin.com/threa...key-based-licensing-new-install-method.65260/
IMPORTANT: We've worked hard to make this process automatic for you. However, this requires you to maintain a relatively recent DirectAdmin version. Please see this thread.
Where to Find Your Key
Login to your client account and view any license by clicking on it. You'll see a new "License Key" row. Do not share this with one, as it is your secure key for that license. If you think your key has been leaked or stolen, no problem: just click the plus (+) symbol and you will see a button to reset your key. This can also be done if you don't see any key associated to your license.
How to Protect Your Key
Your key is secure. Unless someone has access to your DirectAdmin client account, or root access to the server where the key is installed, they cannot see your license key hash. (The license key hash is the string of long characters that makes up your license key.)
We offer extra features to protect your key even further. In your client account, after you click on a license to view it, you will see these extra features:
Installation Procedures
Just follow our install guide, as usual. You will notice that your license key goes where the text "auto" used to be.
Most legacy setup methods still remain. Assuming the license meets the traditional requirements (valid license set to the proper IP), you do not need to know what your key is. You can simply run:
Please note that the oldest "./setup.sh UID LID" method has been depreciated. Our installer will still accept it, but then ignore it, and trigger "auto" instead.
License Update Procedures
Normally, you will never need to use our getLicense.sh script, because the key is permanent. It is not something that needs to be refreshed or re-downloaded to keep the server active. However, you can put a new key on the server by using:
Datacenter Considerations
Updated & moved to: https://forum.directadmin.com/threa...key-based-licensing-new-install-method.65260/
Let us know if you have any questions or concerns regarding these changes.
- The DA Team
- IP Restrictions. You can use this area to restrict your license to a certain IP range. For example, if you wanted to restrict the license to one IPv4 address (e.g. 1.1.1.1) you could enter 1.1.1.1/32 -- IPv6 ranges can also be added.
- Auto IP Lock. This will lock your key to your current DirectAdmin installation, intelligently. It doesn't matter if your server is maintaining licensing sessions on IPv4/IPv6 or a mix of both. Auto IP Lock will ensure only your live DA installation is allowed to use your key. You can disable this at any time (for example, when you want to install your key onto a different server).
./setup.sh auto
./getLicense.sh "LicenseKey"
- The DA Team
