Resolving www.directadmin.com... 167.172.23.237
Connecting to www.directadmin.com|167.172.23.237|:80... connected.
2022-03-01 10:57:35 (118 MB/s) - `/usr/local/directadmin/conf/license.key' saved [1559]
License has expired
Current Server Time: Tue Mar 1 10:57:53 2022
Is not supported anymore, Only Centos 6 64 bits for nowCentOS 5
But we have some CentOS 4, CentOS 5 servers (required due to old customers software). There are only problem with CentOS 5 servers due to "Portioned Licence", which require licence renewal every 30 day. At CentOS 4 servers licences (and DirectAdmin) still works normally, because licence is valid to 2038 year.Is not supported anymore, Only Centos 6 64 bits for now
Yes your license maybe valid but you would not get any updates if your DA version is not > 1.65.4At CentOS 4 servers licences (and DirectAdmin) still works normally, because licence is valid to 2038
why it is not possible to create other link at ./getLicense.sh file, which will let download license.key file for older DirectAdmin versions?@Active8 All help from support is "update to new system". Tried that.
else
$WGET_PATH $WGET_OPTION ${HTTP}://www.directadmin.com/cgi-bin/licenseupdate?lid=${2}\&uid=${1}${EXTRA_VALUE} -O $LICENSE
fi
When you download the new version there is a new getLicense.sh. not sure if the licenses that script downloads are compatible with older version?why it is not possible to create other link at ./getLicense.sh file, which will let download license.key file for older DirectAdmin versions?
current license.key (from www.directadmin.com/cgi-bin/licenseupdate) completely don`t work with DirectAdmin versions older than 1.63.4When you download the new version there is a new getLicense.sh. not sure if the licenses that script downloads are compatible with older version?
OK just tried it myself. but server still gives message that license is expired. Would be a too easy solutionWhen you download the new version there is a new getLicense.sh. not sure if the licenses that script downloads are compatible with older version?
Yes I see. Would be nice if that worked. Wonder what they changed in the license.key then.current license.key (from www.directadmin.com/cgi-bin/licenseupdate) completely don`t work with DirectAdmin versions older than 1.63.4
That's customers risk of not updating their software and your risk wanting to keep supporting ancient software just for the money instead of teaching them they should not stick with that stuff or keep it running at their own risk!But we have some CentOS 4, CentOS 5 servers (required due to old customers software).
They did not, people can still use their lifetime licenses, just not on old stuff. So change the question, why not working more safe and stop using ancient EOL stuff, what's it all for? For customers? Customers=money. Well.... it's the same reason then, right?But Directadmin cut people off from their lifetime licenses. And what's all this for?
In your opinion this is fine. I other opinions its dangerous you should update your OS and the application. Since CVE come out you could be vulnerable. Like you said you dont have to do anything. LS actually did this to force you in to the Subscription model. DA isnt forcing you to change licenses models.I just can't update it to newer version which is perfectly fine.
32 bit code was obsoleted ages ago. DA doesn't support OS' with 32 bit code. Hasn't for a while..But 32 bit CentOS 6 not.
And cPanel stopped with the lifetime licenses years ago, totally unusable anymore, just like other software company's did. These days for most software you don't even get lifetime licenses anymore.
It -does- still work. But you keep comparing it to limited or different lifetime licenses like Windows XP an Lightspeed. You can't run Windows 10 with an XP license.it should still work there because this version was supported on that system at the time of purchase.
Come on, really? So you're going to compare a "lifetime one fee" license which you have to pay $200 a year for updates to a really one time fee DA licenses which has free updates, which is more like "one fee"? You're not being realistic.(for a payment of 140$ respectively 200$ without discount per year/licence for unlimited accounts),
Plain nonsense. There are are lot who will do that, but also a lot who will appreciate and do update. Frontpage extensions? People should be put over the knee still supporting that crap.without exception and all cancelled, also some of them have partly given a 1 star rating on google company ratings.
I've didn't see that before and it was not announced as far as I now. However, I'm not native English and do not understand what this means.These legacy licenses retain functionality in their legacy codebase only.
No it should not. The licence require an updated OS as I said before.it should still work there because this version was supported on that system at the time of purchase.
The Supported OS' are listed here https://docs.directadmin.com/getting-started/installation/overview.html#system-requirementsAs for CentOS 6 32 bit, it is still available to choose in the license panel.
Correct totally agree.Litespeed doesn't force me to do anything.
Good for them. You can buy support at DA to.I can still buy one-year support for my owned license
